How to log AFR and RPM using LM-1 and Evoscan?
Hi all,
Can anyone tell me how I can log my AFR using my LM-1 along with RPM using Evoscan (Using Evoscan to log RPM as I dont have an RPM gauge for my LM-1)
Any help much appreciated
Thanks
Thanks
If you do not have the LMA-2, which I think you do not, then use the Aux out serial cable that you use to download data from the LM-1 to your computer. Connect the serial to a USB to serial cable and plug the USB into your laptop.
Start EVOscan and click on the "wideband" drop down menu and select the correct Com port that your USB cable is using. Then check the "Wideband A/F Ratio" box in the Evoscan display window.
That should do it
That should do it
