First log with Logworks/Ecuflash
Old Jan 4, 2007 | 12:33 PM
  #46
jfitzpat's Avatar
Originally Posted by MalibuJack
Drop Donour a PM, he wrote the pyXEDE libraries and probably has all the information you need to figure out the format of the raw data.
Thanks. Vishnu is also a good customer of ours, so I guess I could tap them as well.
I actually just did it because it because nj1266 was trying to do an equation to convert logged ECU timing to XEDE corrected timing. Since he was swinging by anyway, I spent a few minutes and sniffed the serial connection he was using.
The packet structure is quite simple, and RPM, time, timing (which was sitting at 0x80), and flags stood right out. If it is of general use, I'll flesh out the rest of the values.
-jjf
Old Jan 26, 2007 | 12:51 AM
  #47
jfitzpat's Avatar
Update: There is a new version of both plug-ins (OpenPort and XEDE) included in the LogWorks on our download page.
If you have made additions to your protocol.xml, you will need to add them to the new version. The format changed slightly, since the same file is now used to keep persistant protocol and channel selections between runs.
With all plug-ins you can now 'click through' and have your last settings. In addition, you can run the plug-in with the command line option "-auto" and it attempt to recreate the last connection and setup automatically.
Let me know if you have any problems.
-jjf
Old Feb 6, 2007 | 01:38 AM
  #48
nj1266's Avatar
Guys,
Joe posted this so that we can log Load using the Mitsulogger/Evoscan formula
http://www.innovatemotorsports.com/f...&postcount=110
nj1266
Jan 25, 2026 01:43 AM
mrfred
Feb 26, 2022 06:16 PM
Deepnine
Aug 7, 2010 05:54 PM
nj1266
May 28, 2009 10:05 AM
nj1266
Apr 24, 2007 08:08 AM
