JDM evo wants to use ecuflash?
Old Jan 15, 2007 | 09:35 PM
jrsimon27's Avatar
well i bought my tactrix cable and i downloaded ecuflash to my laptop when i hook it up to my car it says that the wizard cant recognize my ROM i have a 2005jdm evo8 rs, so then it gives me 3 choices
a- start from scratch i choosed this one and it says to contact openecu.org
b-inherit from the list below
c-copy from the list below
so checking the list i couldnt fine my model so what i did was to choose a 2005usdm evo8 it then reads the images but when i open the images they all look like they are not working properly so what do i do?
thanks
Old Jan 16, 2007 | 12:57 AM
jcsbanks's Avatar
On open ECU I posted xml for 8 and 8 MR GSR models. Try inheriting the appropriate one and see how your maps look on your RS.
Old Jan 16, 2007 | 05:36 AM
jrsimon27's Avatar
do you have a direct link for this?
if you say openecu.org where in the site?
thanks
Old Jan 16, 2007 | 06:23 AM
jcsbanks's Avatar
www.openecu.org
Register so you can download.
http://forums.openecu.org/viewtopic.php?t=971
Old Jan 16, 2007 | 03:39 PM
jcsbanks's Avatar
These xmls don't work for the ROM you posted on openecu. I'll try to disassemble it tomorrow and post an xml on the openecu thread, let me know what you need otherwise I'll do:
High octane fuel
High octane ignition
RPM limit
Boost limit
Wastegate duty
Boost desired engine load
Boost control load offset
Old Jan 16, 2007 | 04:05 PM
jrsimon27's Avatar
High octane fuel
RPM limit
Boost limit
Wastegate duty
i need also high octane timing map and low map
thanks
Old Jan 17, 2007 | 02:31 PM
jrsimon27's Avatar
thanks malibujack and jcsbanks for helping me out in openecu.org
know i can see my tables with the xml file malibu posted on openecu
thanks
