How to adjust for a 255 fuel pump
Old Feb 9, 2007 | 02:04 PM
jcsbanks's Avatar
Jeff, I didn't realise I was that close to the edge on it, but you've caused me to look into it which I thank you for! I'm used to this pump on larger engines running lower boost but making more power, and looking again for a higher boost 2 litre is important...
Assuming I'm droppping from 13.5 to 12.0V across the pump under load on the stock wiring, on the Walbro at 90% IDC on 560*4*1.095 I need about 132 lph, so I won't be returning much of the 140 lph the pump should manage at that pressure and voltage. Hopefully it will be a bit nearer to 185 lph at 13.5V, but doesn't give me confidence to increase the pressure any more.
Old Feb 9, 2007 | 07:55 PM
keydiver's Avatar
Jeff Lucius has some nice graphs on his site that will help you figure out how close to the edge you are running. I run a Supra pump myself, and the Walbro HP is about the same. The regular Walbro 255 takes a pretty big dive >70 psi.
http://www.stealth316.com/2-fuelpumpguide.htm
Jeff O.
aka keydiver
Old Feb 16, 2007 | 11:08 AM
SophieSleeps's Avatar
I installed my Walbro and logged my AFR's. They did not change.
Faisalm
Mar 23, 2015 02:11 AM
David Buschur
74
Jan 17, 2007 07:09 AM
Inn-Tune
42
Mar 11, 2006 01:32 PM
umiami80
Aug 7, 2004 10:14 AM
Fourdoor
Nov 7, 2003 08:42 AM
