Cable Recognized...Still wont connect....HELP!!!!!!
Ok, so just like the title states...
I'm simply trying to get into my ECU to make some changes to my map. I've conected before without problems, but now for some reason ECUflash just will not connect.
I've tried uninstalling and reinstalling the drivers 5-6 times now, tried charging the battery, charging the battery and letting the car warm up for an hour, everything i have read in other forums. And still, it will not connect.
I know you've all seen this before...but this is the message I'm getting...
[00:41:52.515] Version 1.29.906
[00:41:52.515] 8 memory models read.
[00:41:53.687] 140 ROM metadata models read.
[00:41:53.687] checksum module "subarudbw" loaded.
[00:41:53.687] flashing tool "wrx02" loaded.
[00:41:53.687] flashing tool "wrx04" loaded.
[00:41:53.687] flashing tool "sti04" loaded.
[00:41:53.687] flashing tool "sti05" loaded.
[00:41:53.687] flashing tool "mitsukernel" loaded.
[00:41:53.687] flashing tool "mitsukernelocp" loaded.
[00:41:53.687] flashing tool "mitsubootloader" loaded.
[00:42:14.531] sending init sequence 1 (0001)
[00:42:17.812] sending init sequence 1 (0003)
[00:42:21.078] sending init sequence 1 (FFFF)
[00:42:23.812] no response to any known code
[00:42:36.140] sending init sequence 1 (0001)
[00:42:39.406] sending init sequence 1 (0003)
[00:42:42.671] sending init sequence 1 (FFFF)
[00:42:45.406] no response to any known code
No matter what I do how how many time I try and solve this problem...it just will not go away, I need some help...please!!!
