first dataloglab power / logs and a few questions
Old Mar 8, 2007 | 07:11 AM
Mr. Evo IX's Avatar
HP / Torque
Log of 3rd gear pull
I know I've got a little dip in my AFR that I should smooth out.
Questions
1. How do I add data tags on my graphcal logs?
2. How do you setup the correction values or is that even recommended? As far as car defntions go I thnk the IX MR weighs 3285lbs, vs the VIII weighing a little less in dataloglab. Also, I live 97feet above sea level and the relative humidity this morning was 75%. My atmostpherc pressure calc has it around 30.10 but it wont take a value less than 75. Ambient temp was 65 degrees. Am I doing something wrong here? zip code is 78539.
3. This program is pretty cool.
Attached Thumbnails first dataloglab power / logs and a few questions-tune-3.jpg   first dataloglab power / logs and a few questions-dataloglab.jpg
Old Mar 8, 2007 | 09:56 AM
Ph3n1x's Avatar
Atmospheric pressure on the news is measured in "inHg", the program reads in "kpa"
30.10inHg is roughly 101 kpa
Ambient Temperature in that program is Celcius not Farenheit
65 F is about 17 C
Old Mar 8, 2007 | 02:44 PM
Mr. Evo IX's Avatar
Thanks, I knew about the 17C, but didnt realize DLL was kpa. What do you think about the weight.. I guess I should take it to the scales but I've read that a IX weighs in at 3285lbs. Is that the entry I should use in the vehicle definition or should I use the value that's in it? I'm guessing it may not matter that much because it's just a software dyno and probably wont be that accurate anyhow but I would like it to be as accurate as possible.
