A/F R... and Knock,,, what should i buy
I need something to tell me the A/F and knock can someone tell me what to buy????
Mitsulogger, or evoflash... whats good im not sure what to get...
Mitsulogger is free, EvoScan is cheap, and I dont know what evoflash is. ECU Flash is the software that you edit and flash ECU's with - does not support logging. You will need a wideband that works with whichever program you choose to log A/F ratio. Evoscan currently supports Innovative, Zietronix, and AEM. Mitsulogger supports the Zietronix ZT2 and will soon support the AEM. The developer is working on Innovative support - you should check the websites of both products for exact details.
You will need a wideband if your going to log AFR. I recommend one of these probably in this order for quality although the Innovative and Zietronix are probably equals. I have the AEM and I think it works fine.
Innovative LM or LC
Zietronix
AEM
You will need an OBDII cable to log with
http://www.tactrix.com
Also available from other vendors and EvoScan is selling cables now too I think.
Mitsulogger - available http://www.aktivematrix.com/forum/
must register to download
EvoScan - available http://www.limitless.co.nz/EvoScan/
must pay to download, has other features that you may or may not be interested in. Also, it is currently in transition to a new version. You could wait for the release because it's sort of inbetween versions right now. It works though!
ECU Flash - if you want to edit or flash the ECU you will need this software http://www.openecu.org/index.php?title=Main_Page
Innovative LM or LC
Zietronix
AEM
