EVOScan/mitsulogger + injectors + load...?
Old Apr 21, 2007 | 08:53 AM
ExViTermini's Avatar
Been tuning on a friends car the past few days, running the buschur(FIC?) 680 injectors. These things are a joke, barely better than stock IMO.
Neway, I've been trying to get the load to read properly, i went to the data.xml file and changed the 513 to my scaling value in the loadcalc eval, but it is still not correct. I'm suspect that I need to change the voltage latency values as well, but I'm not sure as to where?
Anyone have any input?
Both Mitsulogger and Evoscan show the same load values regardless, however if I put a map in there that has stock scaling and latency values, the load shows correctly.
Old Apr 21, 2007 | 09:11 AM
elhalisf's Avatar
buschur sells pte 680's
yes you need to change voltage latency
Old Apr 22, 2007 | 08:15 PM
ok, where to change the latency values in evoscan so it logs right?
