Anyone running 280 cams without P0300 code?
Old May 26, 2007 | 11:13 AM
EvoAnthony's Avatar
I have BC 280's and I have no code....Even before the cams I still never threw a code and I have an 03'. I dont know what to tell you sir....
Old May 27, 2007 | 06:48 AM
honki24's Avatar
Originally Posted by honki24
I needa try that too... I have like 14ish to keep vaccuum up. I needa spend more time on this thing...
I dropped idle timing back off to stockish ~5 and still got it... dunno what else to try.
Old May 27, 2007 | 03:57 PM
rob82's Avatar
Go back to a 7 heat range plug and make sure that its protuding to. The colder the plug and the more removed from the chamber the higher the chance of a missfire. You might want to separate the cam centres too - might give you a bit more dynamic compression.
Old May 27, 2007 | 04:05 PM
aarons05evo1's Avatar
my freind has those cams and no problem
Old May 28, 2007 | 12:29 PM
Evil_1's Avatar
Are those cams pretty lopey? What's the intake and exhaust lift on those?
Old May 28, 2007 | 12:38 PM
Ph3n1x's Avatar
If your an 03 then this will not work for u.
Old May 28, 2007 | 04:10 PM
EvoAnthony's Avatar
Yes they are very lopey...heres a video!
The intake lift is 10.80mm's and exhaust is 10.36mm's.....
Old May 28, 2007 | 04:24 PM
gsrboi80's Avatar
Try using a plug without the protruding tip. I havent gotten a P0300 in I cant remember how long now. Go with BR7ES or BR8ES. These work way better in my car than the protruding tipped plugs
Old May 28, 2007 | 08:37 PM
Evil_1's Avatar
Ok, I threw in some BR8ES. Keeping fingers cross that it will not come back.
Old Jun 6, 2007 | 11:52 AM
Mellon Racing's Avatar
I installed my HKS 280's this time last week, no problems
Old Jun 6, 2007 | 03:27 PM
TTP Engineering's Avatar
Originally Posted by evo 9 guy
with 280 cams you might want to try the bpr9es heat range plugs or go with the hks m45i which is the same heat range but a little bit cheaper that the ngk's. that way a lot more heat with escape the chamber and you wont have as much det/misfires from plugs going out of wack on you.
This is ridiculous advice with no technical merit.
Do not switch to 9 range plugs. If anything, warmer range plugs would improve ignition, not colder.
Old Jun 6, 2007 | 08:56 PM
Evil_1's Avatar
So far, almost 2 weeks and no code . It would always come back after a day or two after clearing it in the past. I'm not sure if switching the plugs did it or adding more fuel and more timing at idle or both. I hope it stays gone permanent.
