Ecuload
Old Jun 11, 2007 | 04:13 PM
jordo's Avatar
Ecuload
Stock evo 9, TBE, hallman boost controller (hard spring)
For some reason my car will only peak 220 ecuload then drop around 155ecuload..
Im thinking I have a boost leak somewhere in the system.
Old Jun 11, 2007 | 04:17 PM
evo 8 ya's Avatar
what boost are you running? 220 load is about 19.5-20psi. That almost sounds like stock boost/load
Old Jun 11, 2007 | 04:37 PM
jordo's Avatar
yeah thats what i was thinking..
im running a halman boost controller with hard spring all the way up, and only getting 220load
Old Jun 11, 2007 | 07:36 PM
Ph3n1x's Avatar
]How do you have the boost controller set up. Where do the respective hoses go to.
Old Jun 12, 2007 | 05:41 PM
jordo's Avatar
bottom line into wastegate nipple.
side line going into bov.
Old Jun 12, 2007 | 07:04 PM
Slava's Avatar
If u had boost leak it would go much higher. What is max boost u see on gauge?
Old Jun 12, 2007 | 08:00 PM
Ph3n1x's Avatar
Your lines are wrong
Reverse them and then turn the boost all the way done. then turn it back up to your desired boost.
Old Jun 12, 2007 | 08:12 PM
Evo_Jay's Avatar
ISnt that wrong?? Shouldn't the boost source (BOV) go to the bottom and the side go to the wastegate.
