Need help on Accel Enrichment Table
Old Jun 12, 2007 | 06:19 AM
alanoh's Avatar
Hi Guys,
I was comparing my stock Accel Enrichment Table with those found in maps posted by fellow members here. I found that my table looks kind of funny. There is no "flow" in the figures when compared to others'. Do you guys think I should copy the common map others are using?
I would like to seek some comments, please
File Type: doc
Old Jun 12, 2007 | 06:54 AM
juyanith's Avatar
I'm no help other than to say the Accel Enrichment table on my tune is closer to the first one you posted. Perhaps someone could explain exactly how this table is used which might in turn explain your "unusual" values.
Old Jun 13, 2007 | 06:10 PM
occultworks's Avatar
I would like to know this as well. Mine looked pretty similar to the one he posted. Like he said there was no flow to it at all. I'm wondering if this just has something to do with the map definition not lining up perfectly, and not actually indicating the proper values.
So would it be okay to replace the values that I pulled with the apparently stock values others have posted.
Old Jun 14, 2007 | 01:05 AM
ko_racer's Avatar
I'd say the xml def was wrong on the other one, I had one looking like that until I used the newer version of the xml file, then it looked very much like yours.
Old Jun 14, 2007 | 04:13 AM
alanoh's Avatar
Ko racer,
Given your ride, I believe I'm useing the same xml definition. Will you be able to share your latest updated xml here?
Thanks
