EvoScan v1.0 to be released next week with Map Tracer support
Old Jul 8, 2007 | 06:29 AM
Mellon Racing's Avatar
excellent, is there a slick way to plug in upgraded injectors sizes and latencies to get accurate load calc yet?
Old Jul 8, 2007 | 06:36 AM
EvoDan2004's Avatar
also is it still able to read the jdm boost mod. do we still need to mess with a file or is it already set??
Old Jul 8, 2007 | 12:28 PM
kreionic's Avatar
+10000 on that. All the add-ons that we did will need to do this again with evoscan 1.00? Like jdm map, 2 byte airflow?
Old Jul 8, 2007 | 04:06 PM
kreionic's Avatar
Originally Posted by erggy
haven't received any?
cause it not out yet
Old Jul 8, 2007 | 08:27 PM
EB05EVOVIII's Avatar
Can't wait till its released.
Old Jul 9, 2007 | 12:47 PM
zeRo IX's Avatar
i forgot how you go about downloading this if you have payed for it?
Old Jul 9, 2007 | 12:53 PM
TouringBubble's Avatar
You will get a link e-mailed to the address you used when you first purchased. I have not received mine.
Old Jul 9, 2007 | 02:16 PM
zeRo IX's Avatar
ah yes i forgot. thank you.
Old Jul 10, 2007 | 05:05 PM
Jumperalex's Avatar
so alpha has been released ... hurry up hurry up [pant pant pant]
[edit] no this doesn't mean I have a copy o 1.00 alpha, just that I saw it mentioned on the web page as being released July 2007
Old Jul 12, 2007 | 04:32 PM
evo4mad's Avatar
Yes some people have v1.0 alpha already.. I have enough feedback from them to keep me busy
Send me your data.xml file from the evoscan folder, and I'll make sure your changes get included in v1.0
(send to mailto:evoscan@limitless.co.nz http://www.limitless.co.nz/evoscan )
Zietronix Boost, EGT and RPM, is now confirmed working and tested...
Innovate MTS chain for aux inputs are still work in progress...
I had to go back to the drawing board on the core sytem because of a few people starting to get timeouts from the hundreds of new features I'm adding into the main logger loop.. I have increased the internal logger speed by 50% so that EvoScan on slower laptops and older cars can keep up !!
Map Tracer will be delayed due to time spent on the core system, and I have got all excited about supporting US OBDII protocol that I have put all my attention into this now...
If the OBDII and Full Evo DTC support is successful today, I will finish the map tracer on this weekend, but it is in the works, and some people are already testing it out for me.
Old Jul 12, 2007 | 04:40 PM
evo4mad's Avatar
first post in this thread has been updated.
Old Jul 12, 2007 | 04:41 PM
kreionic's Avatar
Evo4mad. I am sending you an email now with my evoscan xml for you to implement to the final evoscan 1.0. I have the JDM map and 2 byte airflow in my xml. Check your email
Old Jul 13, 2007 | 07:32 PM
zeRo IX's Avatar
is this out or no?
Old Jul 13, 2007 | 07:39 PM
We need this keep up the good work.
Old Jul 14, 2007 | 08:59 AM
G20's Avatar
G20
Hamis,
i did some data logging last night with the Alpha version and the Zeitronix data logging seem to work great except the boost value need to be convert to psi or bar. It's probably just using whatever returned from Zeitronix and I'm unable to tell what unit it is in. I'll try other functions tomorrow but so far it worked great with no error so. Thank for the good work.
