more boost or more timing?
Old Aug 9, 2007 | 08:35 PM
black E's Avatar
Hey guys!
I would like to get people to give there experience and results on this topic.
Did you make more power with More timing and less boost or with more boost and less timing???
I know this subject has been talked about before but i feel it never really got to a solid conclusion!
Old Aug 9, 2007 | 08:41 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
What turbo?
Old Aug 9, 2007 | 08:55 PM
black E's Avatar
evo 8 with 10.5
Old Aug 9, 2007 | 09:57 PM
evoRS06's Avatar
timing will give you more Tq, more boost will give you higher Hp but lower Tq.
Old Aug 9, 2007 | 10:25 PM
black E's Avatar
OK , but i thougth HP is a measurment of TQ over time , so would that mean more HP?
Old Aug 9, 2007 | 10:33 PM
JohnBradley's Avatar
Add more of both. Welcome to the wonderful world of tuning and the joys of figuring out how to get the best of both worlds.
Old Aug 9, 2007 | 10:45 PM
black E's Avatar
" THANKS!!"
so , find a happy medium?
Old Aug 9, 2007 | 10:47 PM
Exactly. Start by adding a little timing over the stock map then add some boost. Repeat as needed. When you reach knock back up a step and figure out why it happened than try to tune around it. If you cant tune around it then you have reached the end....Or need to buy more parts.
Old Aug 9, 2007 | 10:49 PM
Aby@MIL.SPEC's Avatar
if your on pump, i would shoot for 23-24. boost will taper & adjust your timing accordingly.
i go for 23-24 psi on 91. it makes more power than 21/22 psi with more timing. the power is based off of car acceleration / et compares.
Old Aug 10, 2007 | 10:31 AM
mplspilot's Avatar
28 psi and 20* make my car happy
I'd go with setting boost to where you want it and then go about setting afr's to where you want them, then tuning timing and then go about changing variables till you hit the perfect set up for your car.
Old Aug 10, 2007 | 10:18 PM
lemmonhead's Avatar
24psi on 91 octane???? more like 93octane.
Old Aug 10, 2007 | 10:20 PM
EvoVIIIJeremy's Avatar
28psi wtf wouldnt you be pushing hot air??
Old Aug 11, 2007 | 05:58 PM
dan l's Avatar
Are you sure?
Old Aug 13, 2007 | 07:31 AM
SWOLN's Avatar
Just a thought as I am no tuning wiz, but wouldn't one want to put the turbo in its best efficency range(whichever it is, according to the compressor map) then tune timing after your AFR's are set. Then this would allow maximum flow without the heat of pushing outside the efficencies of that specific turbo.
Old Aug 13, 2007 | 07:34 AM
Boltz.'s Avatar
FCOTM Winner
Thats incorrect.
