Idle Problems with GT35
Old Sep 5, 2007 | 01:53 PM
ymr's Avatar
ymr
Hi , I got a EVO 8, I Install a GT35. I got a great setup with my reflash, but when the car is in neutral , an I accelerate the engine about 5000RPM, then the RPM's goes down, then I got a drop about 500RPM for like 5 second, then idle gets normal.
The question is, When in the reflash can set better this issue? If any of you guys got the right setting for this?
Thanks !
Old Sep 5, 2007 | 01:55 PM
PeteyTurbo's Avatar
Are you running cams at all??
bigric09's Avatar
you need to give more info.... type of turbo (who's) , type and size of injectors, who did your reflash etc.
Old Sep 5, 2007 | 02:01 PM
bluebyu36's Avatar
blow off valve?
Old Sep 5, 2007 | 07:36 PM
Ev0luti0n's Avatar
Originally Posted by bluebyu36
blow off valve?
I second this...
We need your entire mod list to determine any type of faults that can cause this.
