Help ! !
Old Sep 22, 2007 | 09:11 AM
Appauldd's Avatar
Help ! !
EcuFlash can write but can't read....Yes I did a search and I did try the remove and reinstall and I even tried a different version of EcuFlash. I have tried 1.28, 1.29a and 1.32.....all to no avail. What needs to be fixed???
Oh and I was able to read and write just fine on version 0.98.
Next problem....
EvoScan reads 13lbs of boost at idle and it spikes up to 47lbs when I ge on it. My boost gauge reads accurate vacuum and on boost I am only hitting about 16lbs. The car also pulls timing and bogs really bad when I try to get on the gas fast but if I lay into it slowly it works just fine. I am under the impression that the pressure sensor of my car is bad.....Any suggestions???
Thanks.
Paul
Old Sep 22, 2007 | 09:14 AM
RedV's Avatar
Not sure if I can help with the ECUFlash issue, but are the boost readings you're getting with the stock MAP sensor or the JDM MAP sensor?
Old Sep 22, 2007 | 03:30 PM
Appauldd's Avatar
Boost readings are from the stock sensor.....This is so frustrating.
Old Sep 22, 2007 | 05:08 PM
Evo_Jay's Avatar
the stock sensor only read 3.3 psi, so something is wrong.
Old Sep 22, 2007 | 06:23 PM
RedV's Avatar
Is it possible that the "eval" statement in your EvoScan "Data.xml" file somehow either has incorrect values or got configured for if you had a JDM MAP sensor?
If the eval statement is incorrect it could cause you to log odd psi values. As 'EvoKid' said, the USDM MAP sensor only reads up to ~3psi.
I would think that if your MAP sensor was actually providing incorrect voltage readings you would have a SES right now.
The original Evoscan data.xml statement is Eval="1.334x". The statement for the JDM MAP sensor is "Eval=0.19347*x-14.31678".
Not sure if this is your issue or not, but it might help.
Old Sep 22, 2007 | 07:03 PM
[EVO]Cookie's Avatar
The Boost read issue is a calculation atmospheric +0.19348*PSI pay no attention to it. You have to patch the ecu to read the 9's JDM sensor. The Ecu flash problem may be a .NET framework problem make sure you have all the Windows updates.
Old Sep 22, 2007 | 07:34 PM
kstpeter33's Avatar
i just looked at my file and it has the JDM MAP sensor statement, but I dont have a JDM sensor...so I should change it to the Eval="1.334x" right?
Old Sep 22, 2007 | 11:50 PM
codgi's Avatar
Just don't log the sensor if you don't have it. If you don't log it, the equation used to generate the data is irrelevant.
Old Sep 23, 2007 | 05:48 AM
Appauldd's Avatar
What about the bad bogging that I am getting when I get on the gas fast.
Old Sep 23, 2007 | 08:03 AM
Is it bogging or are you getting compressor surge? If it's compressor surge there are a lot of things that can cause that.
Old Sep 23, 2007 | 05:34 PM
Appauldd's Avatar
I wouldn't think it is compressor surge. It feels like the car is pulling timing really hard. Crazy thing is it is running rich.
I am going to try going back to a stock map and start tuning from scratch. Maybe I changed something that I shouldn't have at some point.
Old Sep 24, 2007 | 08:44 AM
roger smith's Avatar
Did you try logging data to try and see if you can find the problem?
You usually hit different loads at different times depending on how you control the throttle so it could very well be knock.
Old Sep 24, 2007 | 07:34 PM
Appauldd's Avatar
I put in a stock map with only the injectors scaled (I have 760's) and the load changed to 300 max. This helped a bit as the pulsing isn't as bad. It feels like the boost is hitting and releasing and hitting and releasing. It won't go over 14 lbs. I ran 22 lbs and the car ran great before I was deployed.
Here is the really wierd part...If I lay into the gas very slowly I can get up to full 22psi boost with no problems. But if I do a quick down shift and mash the gas as if to pass on the highway it bucks and sputters like crazy. Frustrating!
Any how, after some data logging, some research, and some tinkering under the hood, I have discovered what I believe to be is that my boost controller (Buschur Manual style) is not holding as it should. This bleed style controller must have just worn out. It very well could be the reason for the surging. I have an AVC-R that I guess will go in soon.
Oh the joys of getting this car running well after sitting for a year while I was in the land of sand.
Old Sep 24, 2007 | 08:04 PM
nothere's Avatar
how long did it sit?, might be mechanical, something like clogged injectors?
but do a log, my guess is the afr are way wrong.
Hic
Jun 14, 2016 09:28 AM
NightHawk
Jun 8, 2015 06:28 PM
ball7068
Aug 31, 2012 07:48 AM
rstchris
Jul 23, 2011 06:18 PM
fid
Jul 13, 2008 11:39 AM
