how do I know
Old Sep 29, 2007 | 05:03 AM
chaz517's Avatar
how do I know
How do I know what inputs to use when using the HP/TQ graph In Data Log Lab so it automatically change the sae rating and such? Stuff like tht
Old Sep 29, 2007 | 05:15 AM
recompile's Avatar
If you're referring to weather conditions for SAE correction, check your local conditions at www.accuweather.com and pump them in.
Old Sep 29, 2007 | 06:40 AM
chaz517's Avatar
Wat about drag coefficient? Is that all I need is temps and huimidity and stuff? And gear ration and weight? I'm at work so I'm not looking at DLL right now thanks
Old Sep 29, 2007 | 06:54 AM
recompile's Avatar
DLL should have a definition file for an Evo VIII that includes drag coeff, gear rations, etc. Select the right definition and then just put in contents weight (your weight + any other things inside or that you've added/removed)
Old Sep 29, 2007 | 07:51 AM
chaz517's Avatar
Oh ok sweet I seleceted usdm 5 speed evo so I should be good t go I believe ill check itn out when I get outta work thanks man
