Vehicle Speed Sensor Readings
Old Oct 4, 2007 | 10:05 PM
Jack_of_Trades's Avatar
When I log vehicle speed with evoscan it rises in large steps rather than a smooth graph.
1. Is this common with our VSS?
2. Can the frames/sec be increased?
Also, when I run my Power & Torque graphs in evoscan, it never registers the rpm where I get peak power or torque in the left column (i.e. 321HP@0rpm, 319TQ@0rpm). How do I get it to read the rpm value??
Old Oct 5, 2007 | 03:49 AM
roberttonge's Avatar
Evoscan Alpha
I get the same eratic logs with "speed" in the alpha version......
Old Oct 5, 2007 | 08:57 AM
cpoevo's Avatar
It does not sample at the same rate as some of the other parameters. RPM do the same thing unless you did the RPM 2 Byte mod.
Old Oct 5, 2007 | 10:40 AM
Ralph's Avatar
My RPM's don't do the same as speed, stock EVOScan settings.
Request: 21 | 31.25x
Old Oct 5, 2007 | 11:28 AM
RazorLab's Avatar
I know in DLL if you have the log open, produce a power chart and go back to the log the speed will be smoothed out via interpolation. Not sure if it's the same in the new evoscan with powercharts as I do not use it for that.
Here are some charts after interpolation has been done:
Old Oct 5, 2007 | 11:34 AM
My standard rpm readings are almost identical to my 2 byte mod readings in evoscan (speed evaluation formula is 1.2427424*x). RPM never stepped really. If I could get evoscan to interpolate between the points, that'd be cool. The evoscan never alters the speed curve no matter which charts I go through, in any order.
Does anyone know the BARE MINIMUM parameters you need to log to calculate the power & torque graphs?
Old Oct 5, 2007 | 11:36 AM
EvoBroMA's Avatar
time and rpm
evo4mad
May 5, 2015 06:22 PM
evo4mad
115
Feb 3, 2010 06:52 PM
divine_evo
Feb 2, 2009 03:09 PM
kstpeter33
Sep 23, 2007 10:18 PM
