strange problem with launch, thinking it is ecu related..
Old Oct 7, 2007 | 08:06 AM
Nuked's Avatar
I was reading thru the nlts thread and noticed this users post...
Originally Posted by Titanium
My factory 5k rev limit just holds at 5k...like an auto w/ a stall converter, and I read vaccuum. When we tryed it with NLTS, it bounces at 5k to about 4750 and bounces to about 5 psi or so.
Might not work, I dunno. Oh well.
Last time I was at the track, When I launched the car it was ok till 6k rpms (my 2step limit). Whenever it hit 6k rpms it just held similar to the quoted poster. Did this again in the other gears. If the car is sitting the 2 step works normally, bouncing.
I originally thought it was something with the clutch, as it is stock with some miles. It does not however "slip", even in the high gears/high rpms it has not slipped on me yet.
I am thinking that there is something in the ecu that is engaging some kind of function???
I will attempt to simulate it again today and get a log of it. Anyone have any ideas, or things to log??
SQ
Old Oct 7, 2007 | 10:40 AM
Jack_of_Trades's Avatar
So your saying that your stationary rev limiter works fine off the line, but its ALSO working through every other gear at 6K rpm? For that to happen, the ECU would need to believe the car hasn't started moving yet, meaning its not getting signal from the speed sensor. If its not that, it would have to be that the regular rev limiter and the stationary rev limiter are both set to 6K rpm.
If I am understanding you correctly, of course.
Old Oct 7, 2007 | 12:26 PM
Nuked's Avatar
The stationary worked fine off line, let out clutch when motor hit 6k it just stayed there for a second (like the quoted poster described), then it freely reved to 7500, shift to second and it did it again thru out the other gears.
My stationary limit is 6k, my overall limit is 8100.
SQ
Old Oct 7, 2007 | 12:36 PM
06EVOIX SE's Avatar
sounds like clutch slipping a little
Old Oct 7, 2007 | 12:47 PM
eponti's Avatar
^+1
Old Oct 7, 2007 | 01:26 PM
Yeah, I'd say the clutch is slipping. Maybe its not fully engaging (from wear)and the clutch pedal needs to be adjusted?? That might help a bit.
Old Oct 7, 2007 | 01:59 PM
Titanium's Avatar
Yeah, or a tuning glitch (rich spot at that rpm/load spot). When mine knocks enough to pull timing it does something like that .
That quote IS refering to stationary rev limit. I noticed both the "valet" rev limit and the NLTS rev limit bounce as expected, but my stationary rev limit still holds an even RPM.
Old Oct 7, 2007 | 03:40 PM
Nuked's Avatar
Probably just the clutch then. I will be installing a new one soon, so see if the problem goes away.
SQ
crak
906
Aug 14, 2022 02:41 PM
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
tequila357
Feb 18, 2016 11:42 AM
kimsan808
Pacific Northwest
Jun 16, 2012 01:55 PM
mexevo
Nov 14, 2007 08:55 AM
