How to MOD your ROM with NLTS or others!
Old Nov 10, 2007 | 03:27 PM
  #46
kreionic's Avatar
Originally Posted by Inprogress
Kreionic,
Thanks!! What value did you put for NLTS Speed threshold?
I left it at 30km/h. A few of my friends were having issues with the nls with the 1-2 shift so they set it just over 1st gear top speed
Old Nov 10, 2007 | 03:31 PM
  #47
Inprogress's Avatar
ah ok, thanks! I prob wont worry about it as I prob wont be using it yet...
Old Nov 20, 2007 | 07:37 PM
  #48
Wheatley's Avatar
Love the mod....had an idea pop into my head today. I was thinking about spraying next year and was wondering if anyone had any problems using the ntls while spraying? Thanks if anyone can answer the questions.
Old Nov 21, 2007 | 11:24 AM
  #49
8UpUrV8's Avatar
Um... I had done the NLTS mod wrong yesterday, I didn't put the scaling where they were supposed to go- and the car died after 2 seconds of running and wouldn't crank back over. Did I do any harm when the car was dying?
I put the old flash back on and it works fine again. And today I've changed what needed to be changed so it's fixed.
Thanks
Old Nov 21, 2007 | 11:39 AM
  #50
coolnick's Avatar
This is an awesome walk through.
Old Nov 22, 2007 | 05:53 PM
  #51
Evo8Emperor's Avatar
Ok a question. I recently had a my rom tuned by a friend to get me started. Now when i gave them to him they only went to 260% load on the x axis for both ignition and afr. Now when I go to copy the maps to tephras rom I dont have them up to 300 like mine. Is this because his car is hitting a higher load than mine so it wont show on ECU flash for me ? I tried changing the x axis values to 20 instead of 18 but it changes them for every hex opened under ecu flash not just the one you are in. Anyone have any idea of what i should do ?
edit:: spoke to soon figured it out.
Old Nov 23, 2007 | 09:42 AM
  #52
dryad001's Avatar
Finally got this done since the car will be down for antoher week. I cant wait to give it a try.
Old Nov 26, 2007 | 12:29 AM
  #53
RickU's Avatar
thank you so much...i needed this. Btw how do you make a copy of whatever you are watching in your laptop so you can post it up like you did?
Old Nov 26, 2007 | 05:06 AM
  #54
phenem's Avatar
Just used mspaint and took screenshots.....and "the gimp" to add the text and edit it further....
~Z
Old Dec 21, 2007 | 11:28 AM
  #55
Wheatley's Avatar
Anyone?
Old Mar 5, 2008 | 04:30 AM
  #56
Youngsyr's Avatar
Can this be added to the list of useful links, please?
Old Mar 5, 2008 | 05:47 PM
  #57
Jack_of_Trades's Avatar
I am creating a webpage with this info in VIDEO tutorial form this week. It will pertain to Tephra's newest v5.0 patch. Sometimes it makes more sense to SEE someone go thru the steps. Tephra usually puts this in his first post when he launches a new patch so its usually easy to find. Not sure if it needs to be in the stickied section.
Old Mar 14, 2008 | 10:36 AM
  #58
Chemwarrior's Avatar
You can also push CTRL+ALT+PRINT SCREEN/SYSRQ to get a screenshot. Just right click and copy onto your desired target after you do that.
Old Mar 14, 2008 | 11:08 AM
  #59
TouringBubble's Avatar
I was thinking about this today ... a customer of mine uses the NLTS mod and wants to spray soon as well. My immediate thought is to use the top clutch switch to deactivate the nitrous/fuel solenoid so when the ignition cuts the spray will cut too.
Old Jun 30, 2008 | 04:30 PM
  #60
lan_evo_mr9's Avatar
Angry TephraMod V5
Hello Out there . I am having trouble with this mod , I do all the coping and past to the xml file and i try to save it and i get an error. MY QUESTION IS I AM USING WINDOWS VISTA ,I DOWNLOADED MY ECM FILE WITH IT AND , ALL YOUR EXAMPLES WHICH LOOK VERY GOOD ARE USING WINDOWS XP. IS THIS A PROBLEM OR IS IT OPERATOR ERROR ON MY PART. BEFORE I PULL THE REST OF MY HAIR OUT TRYING THIS AGAIN I WOULD LIKE TO KNOW.
THANKS.
