These Open-Loop values correct for fuel efficiency?
Old Oct 26, 2007 | 12:59 AM
Inprogress's Avatar
I am basing these setting upon what JohnBradley had reccomended in another post...Are these the correct values for Open Loop Load #2 and the High Octane Fuel Map?
The cells that I'm particularly concerned about in the high octane fuel map are the ones in the white area,
1. Should there be a better transition from load point 30 to 40?? Is it ok to go from 14.7 to 15.5 so suddenly?
2. Since I have a 5-speed would it be ok to take the reccomended settings to 4k RPM from load points 40-80??
[img=http://img219.imageshack.us/img219/6236/highoctanefuelmapopenloez9.th.jpg]
Are the values ok for Open Loop Load #2 as well? I made no changes other then from 2k to 4k.
This was really exciting information for me seeing as how i'd get around 210-220 per tank with mostly highway driving seeing very little boost. Any help would be greatly appreciated!!
BTW, when I say 210-220, that's usually before the light comes on, or when the light comes on for the very first time, sometimes not at all.
BTW, thanks for the posting these settings JohnBradley!!!
Old Oct 26, 2007 | 06:04 AM
nothere's Avatar
fun stuff isn't it, I haven't been able to try this mod yet but-
210 mpg indicates something is WRONG. Unless you have very oversized tires with little air pressure. Drive over 90 miles an hour all the time.
I'd suggest you either contact the tuner or another, or post some logs and see what people have to say.
Old Oct 26, 2007 | 09:18 AM
honki24's Avatar
lol, I've never been able to get past 270 miles on a tank.
If you're just going for fuel economy (which is odd considering your choice of vehicle) lean out on the fuel map and pull a degree of timing or so around peak torque (150ish load, 3500-4500ish RPM) Run @ 12:1 and remove whatever timing necessary to keep away knock. Of course you can't do any of this w/o a logger and a WB.
edit: btw your filename has "jestr" in it... might rethink posting those pix.
Old Oct 26, 2007 | 10:02 AM
roger smith's Avatar
Can you report if this works or not? Compare a log from before looking at a specific RPM,load,throttle position and check your injector pulse width.
Then after you make these changes check again at the same RPM,load,throttle and see if pulse width is smaller.
I tried this just with AFR at idling and it made my pulse width go higher actually, so I never continued with this forced open-loop.
And Honki, you won't save much gas if you just try to economize peak torque I think. Most people spend the majority of time cruising while driving so you'll save the most gas if you economize your cruising. Acceleration only accounts for a small percentage of total driving time (unless you're on the circuit).
Old Oct 26, 2007 | 10:41 AM
Inprogress's Avatar
You've gotten 270, I've never gone past 240...I'm not JUST GOING for fuel economy, I saw a post by JohnBradley where he said this would help fuel economy and so I wanted to try it. Why would I lean out the upper load cells? When I hit those I already know my fuel economy is going to the crapper, its a given. I'm talking about cruising around town, which is why I stated Open Loop
Old Oct 26, 2007 | 10:42 AM
Inprogress's Avatar
What logs would i post? just cruising around town?
I have 245/40/18's on it right now, what tire pressure do you suggest?
Old Oct 26, 2007 | 10:58 AM
JohnBradley's Avatar
I have never been able to verify that it does anything at an idle. In fact I am pretty sure it doesnt. However like I stated in the other post you can see the difference watching your wideband when it stops bouncing in closed loop and gets very close to rock solid in open loop. If you wanted idle control you will probably have to modify the TPS open loop table as well to make it play ball. It will increase mileage though, and you can see the difference in the color of your tailpipe assuming you run catless.
Inprogress yes you can also adjust the values at 4K. Right now since I am lazy and dont use my car for long trips very often I have done the same thing (no 6th gear currently) since I cruise at 3800rpm or so. I still manage to get 23.5mpg at that rpm and 60ish mph.
Old Oct 26, 2007 | 11:02 AM
Inprogress's Avatar
SWEET! So the values in both the tables look correct, aside from the 4k range where i'll lean it out from load 40-80.
I don't need to worry about a smooth transition or anything? it goes from 14.7 suddenly to 15.5 you know?
Also, is the Open Loop Load setting look ok?
THANKS a bunch JohnBradley!!!!
Old Oct 26, 2007 | 11:10 AM
It looked like it ramped up slowly enough to me in the one snapshot you posted. You might experience some issues if so just drop those 15.4's 15.1 or something. To be 100% honest it all depends on the rest of your mods and what your WB tells you is happening. I only posted the one map as a guideline of sorts.
Old Oct 26, 2007 | 11:14 AM
Inprogress's Avatar
Could I just change the values in Load Cell 30 to 14.9? Or just leave those alone and change values in load cell 40 to 15.2? I guess I'll back down on the fuel settings and drive arond and do some logs see what happens.
As for the Open Loop Load table, that checks out ok?
Old Oct 26, 2007 | 11:33 AM
Yes and Yes.
Mine personally is completely 45% till about 5K and then I just have 0 so it will automatically be in open loop.
Old Oct 26, 2007 | 01:38 PM
RazorLab's Avatar
A wideband and logging load is essential to this.
You have to know what load columns you are in at various MPH and gear loads while cruising on the hwy.
example:
I had set certain load columns to be 15.5 in my fuel map. This came out to be 15.1-15.2 on my wideband while cruising at 65-70mph in 6th gear on the hwy. All was good in the world.
That night in less traffic I was cruising at 80mph in 6th gear at about 3400-3500 rpm. My wideband showed 14.2, obviously this will make fuel mileage even worse then if I hadn't changed the open-loop tables. I was in a different load column then, the way I have my fuel maps rescaled the AFR in that column and RPM was about 14.7. So I had to lean out that area as well.
Wideband and logging load is essential.
Old Oct 26, 2007 | 02:33 PM
Inprogress's Avatar
example:
I hear you on that, I'm just going to use JohnBradley's figures as a starting point and geek around and see what works best...
Also, you mentioned you had to change your open loop tables, which exact tables did you have to alter if you dont mind my asking?
Old Oct 26, 2007 | 02:48 PM
I think he's talking about the high-octane map. That whole map is referenced under open-loop. Maybe he had the map at the default 14.7 at cruising areas and if he left it like that then he's be running 14.2 AFR.
Could you report back on the injector pulse width thing if you ever get a chance?
I have ECU+ and it supports front o2 sensor simulation using a wideband and you can set the AFR target for closed-loop, like raising the normal 14.7 to 15.2 or so. Just explaining why I haven't tried this forced open-loop method.
Old Oct 26, 2007 | 06:43 PM
ohhgyeahfasho's Avatar
we cant just use this without a wideband? i want to try this but all i have is a logger, my wideband is broken =(...
