Which of these is the correct scaling for the PTE 780cc Injectors?
Old Nov 4, 2007 | 03:12 PM
Inprogress's Avatar
I've got two different values for scaling and am not sure which to use, both say they work great so I don't really know which to use...
https://www.evolutionm.net/forums/sh...d.php?t=300990
OR
Injector scaling: 665
Latency:
4.69v 3.312
7.03v 2.184
9.38v 1.368
11.72v .888
14.06v .600
16.41v .408
18.68v .288
Help would be appreciated, thanks!
Old Nov 4, 2007 | 04:08 PM
A418t81's Avatar
There is no correct or incorrect. Your values may differ from others out there. You need to use your fuel trims as your guide as what to change. Thats info is in those same threads you've been reading as well.
Old Nov 4, 2007 | 06:53 PM
Inprogress's Avatar
I realize that, but it seemed the values that I've shown via the link have been ones people have used more with success, if what you say is true then wouldn't there be more variation?
Old Nov 4, 2007 | 09:37 PM
JohnBradley's Avatar
The second ones are pretty close to what I use for my FIC750 (787cc) and it worked really well for me. I have the scaling at 650 or 665...I dont have my lappy with me so I cant double check to be sure.
Old Nov 4, 2007 | 09:39 PM
Inprogress's Avatar
Cool, thanks! I'll probably try the 665 value first, unless my tuner can get in contact with me before that!
Thanks JohnBradley!
Old Nov 5, 2007 | 03:52 PM
Inprogress's Avatar
Will the latency values be the same for everyone though??
Old Nov 5, 2007 | 04:15 PM
dudical26's Avatar
I have my PTE 780's set at ...
scaling - 696
Latency -
3.504
2.184
1.224
0.96
0.744
0.552
0.432
Old Nov 5, 2007 | 08:49 PM
Inprogress's Avatar
scaling - 696
Latency -
3.504
2.184
1.224
0.96
0.744
0.552
0.432
Thanks for posting those! I'll try and see if those do anything, right now my wideband is going all over the place
Old Nov 7, 2007 | 10:06 AM
Inprogress's Avatar
I'm still having trouble scaling and adjusting the latency values...
Anyone know what would be a good starting point? I was told to add +.300 to each stock latency value and watch the wideband, at which point I should take away .050 from the 11.72 and 14.06 cells until the wideband stops bouncing around and idles at 14.7 like it should.
Is this correct? I don't need to change the other tables?
Old Nov 7, 2007 | 10:34 AM
joedr's Avatar
EvoM Moderator
3.504
2.184
.96
.792
.552
.432
696
Fast_Freddie
Oct 30, 2023 01:56 AM
daveheit
Jul 21, 2016 01:14 AM
dontek
Jul 7, 2011 09:10 PM
03lances
Nov 20, 2009 12:19 PM
wip
May 17, 2009 06:09 PM
