engine braking effect
Old Nov 25, 2007 | 03:48 PM
  #46
tephra's Avatar
hrmm, mine do it all the time... you can see the IPW drop to 0 and then the AFR slowly goes upto 60 or whatever the max is
maybe your throttle cable is pulled so tight that its slightly keeping the throttle open?
Old Nov 25, 2007 | 04:24 PM
  #47
JKav's Avatar
Injector cutoff will depend on rate-of-change of throttle position. Let off the throttle slowly and the injectors will remain on. Lift abruptly and the rate of change will exceed the threshold value, and the injectors are switched off.
All cars with EFI work this way...
Old Nov 25, 2007 | 04:55 PM
  #48
tephra's Avatar
hrmm ok - that makes sense... I have found rate of change algorithms in the ECU so maybe thats half of it
but presumably there would still be a min RPM as well...
Old Nov 26, 2007 | 08:04 AM
  #49
honki24's Avatar
Yeah, I try not to abruptly modulate any pedal. lol bad habbits tend to show up on the roadcourse... very unsettling to snap off the throttle. Also, perhaps it has something to do with the fact that, like you said, my TPS voltage was always a little high. I've since lowered it, but noticed no bucking still.
Old Nov 26, 2007 | 08:41 AM
  #50
JKav's Avatar
Correct
barneyb
Dec 9, 2016 08:41 AM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
GreeceS13
AEM EMS
Nov 22, 2015 10:46 AM
RxRA
10
Nov 25, 2012 10:21 AM
RichK@AMS
Automotosports - Illinois
10
Jun 25, 2007 01:05 PM
