RPM/load Values
Old Nov 9, 2007 | 08:52 AM
Nevonate's Avatar
RPM/load Values
Sorry, i'm still new ot ECUFlash. Sometimes when I load my ROM, the values for load and RPM are random numbers. Any ideas asto why this is the case?
Old Nov 9, 2007 | 08:56 AM
TouringBubble's Avatar
Endian issue with newer ECUFlash versions. I'd tell you how to fix it, but I'm not at my tuning machine right now and would probably mess it up. All you have to do is reverse the endian value in the edit scalings section.
Old Nov 9, 2007 | 06:55 PM
darthsydwayz's Avatar
Works
Yup I had that same problem with the evo8 rom that is modded for a 3g. I flipped all the endian's from little to big on the funky x and y axis scalings and voila. Works great. Thanks for the info..
Old Nov 12, 2007 | 11:52 PM
kesnut's Avatar
endian's... can some one explain this?
Old Nov 13, 2007 | 04:07 AM
tephra's Avatar
wikipedia it
endianess is the order in which the CPU stores bytes of a word.
EcuFlash prior to 1.31 had a bug where the endian was flipped, thus all the XML's had "little" as their endianess.
1.31+ had the fix for this bug, thus all the little's actually worked and all the XML's broke.
basically if you are using 1.31+ edit your XML and find any "little" and change to "big".
1.31 and below make sure everything is set to "litttle"
