LogWorks is working, but evoScan is acting up...please help...
yup, most of the important inputs
http://www.innovatemotorsports.com/support.php
you prolly already have it on your computer but have not noticed it.
"open port 1.3" keep clicking until it disappears then open logworks and start a log .... bingo.
Also, how do I get to see all of these channels? Can the data be exported to a excel file?
When I open logworks all I see is a afr gauge, and the usual toolbar above, how do I get to loggin the other variables? Does my laptop have to be connected to the car via the tactrix cable for the other variables to be shown?
Thanks for this help!!
have your ecuflash cable plugged in,(but do not have ecuflash or evoscan running) your serial cable from LC-1 connected, motor running, open "openport 1.3"( you might have to select mitsu or something like that) now, click start logging. nothing will happen,
click logworks, click file, click start realtime log. you should see a graph with a bunch of inputs on it.
for now don't try the 2byte load, just run the 1.3 and logworks as it comes.
if you downloaded logworks it should be there, maybe still within the program, look within the (start~ all programs) on your windows.
if you can't find it go to the link I posted above and you will see. it should have been part of the logworks package.
listed as Openport
listed as Openport
Well I'm an idiot...I had an old version of Logworks (got it off the install CD that came with LC-1)...I downloaded the new one and I see "Open Port 1.3" now...
Thanks nothere!
Thanks nothere!
Jorge,
I never got around to installing 2 byte load till now,
something funny with my 2byte load. reads way high, like in the 200 area while still in vacuum.
just put your file into my logworks 2
