Went for a drive
Old Nov 22, 2007 | 05:12 PM
tephra's Avatar
I would like to write out a map of which value the ECU uses and when, but its kinda complicated - hopefully in the future
Suffice to say if you log all three (raw, baro, and baro+temp) then that should give you a better idea of what the ECU is doing...
However for the casual tuner raw is usually close enough
Old Nov 22, 2007 | 05:48 PM
dudical26's Avatar
Just to clarfiy the value with the raw +baro&temp is what the ECU is actaully using for fuel and ign.
Right?
Old Nov 22, 2007 | 06:08 PM
JohnBradley's Avatar
Right?
I saw one instance of that both today and yesterday while logging. The load variation was off by almost 20% so it had pushed the timing to the next cell and I was wondering why I had a 3* advance in my log when I should have been seeing a 5*. I ended up switching everything over though based on those instances and didnt bother to double check and see if I could replicate it again. I had set all 6 timing maps the same though just to make sure it wasnt an interpolation error and when David posted his log yesterday it got me thinking that maybe thats what I was seeing.
I dont have any disassembly to back up my claims just my observations.
Old Nov 22, 2007 | 06:10 PM
tephra's Avatar
kinda
basically:
for fuel the ECU either uses Load_Raw or Load_Baro_and_Temp - it would appear the condition is something todo with being in closed/open loop.
for timing: the ECU uses either Load_Baro or Load_Baro_and_Temp - it would appear it uses Baro_and_Temp when air_temp is less than 65(25*C) and only Baro when air_temp is greater than 65(25*C).
I could be 100% wrong thou
Old Nov 23, 2007 | 07:36 AM
dudical26's Avatar
hmmm, that makes this even more confusing, lol.
I suppose load_baro_temp makes the most sense to use since it seems to be used by both timing and fuel sometimes. Which is not true for load_raw or Load_Baro which are used by on or the other but not both.
Old Nov 23, 2007 | 09:07 AM
Nuked's Avatar
Interesting. I wonder if this is why my car tends to knock with cooler weather as opposed to the warmer weather? ECU looking at lower load cell, with more timing, but same boost as warm weather = knock?
SQ
Old Nov 23, 2007 | 04:16 PM
tephra's Avatar
yeah I had this discussion with eric, in warmer weather there is less air density thou - so I guess it evens out...
Old Nov 28, 2007 | 08:06 AM
evo 8 ya's Avatar
Originally Posted by JohnBradley
Dan,
I dont have one local to play with but I would think that the progression is the same as the IX. So if your 2 byte values are 35164/35165 add 6 to both of them and then log it.
I have a 11 rom and added 2-byte in the MUT table. How would you add 6 to the MUT table?
nj1266
Jan 25, 2026 01:43 AM
David Buschur
225
Dec 12, 2014 09:31 AM
Anubis18
Sep 20, 2013 02:39 PM
Jim in Tucson
Nov 21, 2010 09:29 AM
