Idc% Evoscan 2.0?
Old Nov 25, 2007 | 07:12 AM
fastrob691's Avatar
Idc% Evoscan 2.0?
I can't get the IDC % to display on the new evoscan? Any ideas? It logs the IDC just not the percentage, it worked on the old version, otherwise no complaints.
Old Nov 25, 2007 | 10:15 AM
EvoBroMA's Avatar
just grab the eval out of the xml from the older version.
IDC% is based on injector size, so he may have taken that out in 2.0
not only that - but the stock ECU uses a smaller injector size than stock, so you gotta take your pick on what size injector you want to use to calculate %.
cause theres two sizes you can use even when bone stock.
Old Nov 25, 2007 | 12:10 PM
Evo_Jay's Avatar
You have to have injector pulse width selected to get injector duty cycle %.
Old Nov 25, 2007 | 12:32 PM
PVD04's Avatar
Logging IDC% does not require injector size. The calc is only related to injector pulse width and RPM.
-Paul
Old Nov 25, 2007 | 06:57 PM
EvoBroMA's Avatar
-Paul
yup your right. im an idiot. dont know why i remember seeing injector size in the eval. IDC% is independant of injector size.
