questions about simple log parameters
this was copied from the general tuning forum to this one, it was suggested that it would fit in better here, and i was unsure of how to go about moving it, so sorry about the double post. here is the link to the orig https://www.evolutionm.net/forums/sh...=1#post5019107
hey guys, just a couple of quick questions about this log i took. its pretty much the first one that was somewhat complete. sorry if i seem a little remedial on this subject but i am trying to learn.
its an 03 VIII btw with some simple bolt ons, intake tbe mbc etc. i log this using mitsulogger and the tactrix cable. and we did it during the day and had a hard time finding a good place to do it that was somewhat safe, so i will get back to it come out with a little better data, i also have not installed my wideband o2 yet. its an lc-1 ill do more logs when i get that bung in and hook everything else up.
so i have attached the spreadsheet below,
first question why when i am completly off the throttle does it show 14.51 and is that a big deal?
also around 3100 rpm theres two spots with 6 counts of knock, and can someone explain the afrmap section and the 02 column is that voltage?
sorry for the noob style questions, ive been reading a lot on this and am still trying to understand this. so i guess i feel that this is too lean especially for a stock tune,
i am running abou 21 peak psi.
if you need more info or any other questions to evaluate let me know.
Thanks for any input in advance!!
Ethan
p.s. sorry that it is in zip format i couldnt post a excel file on here or a word doc more then 100k, seems kind of a small window to me. either way let me know if you have trouble opening it.
Ethan
hmm for some reason its not letting me attach the log again so unfortunately you'll have to look at it in the other form im sorry about this.
thanks!
Ethan
thanks!
Ethan
