Up to Date IX XML for EcuFlash
Old Dec 30, 2007 | 09:31 PM
Tek3Evo's Avatar
As I get further and further into learning EcuFlash and all the MODS available, I am starting to see quite a few errors in the XML file for the 88590015 ROM for the IX. Does anyone have an up to date XML File definition for this ROM that has the latest corrections in it. I'm not worried about the MOD definitions, I can add that stuff. I just want to make sure I haven't missed reading a thread about some correction that is needed and I overlook it. I am using version 1.29a but I'm sure others would benefit from higher version corrected XML file as well.
Old Dec 31, 2007 | 02:55 PM
kreionic's Avatar
What all are you looking for in the 15 rom? In mine I have jdm map, 2 byte load, 2 byte airflow, tephras patches, MUT tables, lean spool disable/enable, idle tables etc... I might be missing a few things
Old Dec 31, 2007 | 03:00 PM
Tek3Evo's Avatar
I ran across an article that showed fixes for the correct idle RPM settings and thought I read one a while back for another item, just can't remember what. So I thought I'd see if anyone had an XML that had all the corrections found to the definition so I don't miss anything.
Old Jan 5, 2008 | 12:02 PM
Tek3Evo's Avatar
Nobody has any input for me?
Old Jan 5, 2008 | 12:18 PM
TouringBubble's Avatar
the idle table are really all that I've technically "changed" from the original XML. I've added the correct idle tables, 2-byte load, 2-byte airflow, lean spool, JDM MAP settings, ECU boost control changes and Tephra's mods.
The only thing you might be thinking about is the fuel trim change for EvoScan where the low and high trims were reversed.
Old Jan 5, 2008 | 12:58 PM
Tek3Evo's Avatar
great. thanks. I think that is exactly what I couldn't remember.
