.xml file help
Old Jan 15, 2008 | 03:24 AM
rolly1818's Avatar
Registered User
.xml file help
when i copy my rom from the ECU using Ecuflash i get the following:
Don’t know how to upload pics so here is the Rom Info below:
Make: Mitsubishi
Model: Lancer
Submodel: EVO 9
Transmission: Manual
Year: 2006
ECU ID: (blank)
CASE ID : (blank)
Internal ID: 89980000
Flash Methos: mitsukernelocp
Memory Model: SH7055
Checksum Module:
one weird thing I bought this car second hand and it is a JDM 2006 EVO IX, but the Rom info says its a USDM ECU, so I think this ecu was bought for the car by the previous owner or tuned for the previous owner somewhere in the USA.
I was told i need a xml file to read the rom...anyone know where i can find this?
Thanks Guys!
Old Jan 15, 2008 | 04:23 AM
R. Mutt's Avatar
Post up a copy of your ROM and I'll see if I have an appropriate definition file for it...or make one. Don't forget to save a copy of your ROM in a safe place...burn it to a cd if you have to. If your car came with an immobilizer and you lose the original ROM you could under a lot of stress in the future if something goes wrong.
When you downloaded the ROM what did you inherit from?
Old Jan 15, 2008 | 04:50 AM
R. Mutt's Avatar
Most everything in this definition file should work. Stay away from the VVT Map 2...it's not usable. Again...make sure and save a copy of your ROM in a safe place.Don't hesitate to contact me if you need any assistance, especially if you're not sure about something.
File Type: zip
