Most 2004 Evo Rom?
Old Jan 28, 2008 | 08:35 PM
nj1266's Avatar
Most Used 2004 Evo Rom?
What is the most commonly used 2004 Evo rom? Anyone has a stock one to share with me?
Thanks
Old Jan 28, 2008 | 08:46 PM
JohnBradley's Avatar
969420008 I believe it is...I have seen more of them than the 007 and 015. Could be coincidence though i guess. I should have one somewhere...I think I have your Email...let me go home and grab my lappy and I will look and if I do I will send one your way.
Can I ask why?
Old Jan 29, 2008 | 05:07 AM
FuelsResearch's Avatar
http://www.aktivematrix.com/forum/dl...ile&file_id=14
Bane to my existence.
Old Jan 29, 2008 | 08:00 AM
donour's Avatar
Originally Posted by FuelsResearch
That's my file, what's wrong with it?
d
Old Jan 29, 2008 | 08:27 AM
JKav's Avatar
I just used Donour's 0008 file in my '04 in lieu of 0007 once I switched the stepper values. Seems to work fine so far... what's your beef, FuelsResearch?
Old Jan 29, 2008 | 08:49 AM
Easy fellas.
NJ asked for a stock rom, I gave him a link. JB may have emailed him one as well.
Nothings wrong with it, the rom is apparantley very different from others....so patches, mods etc. tend to come out later or need more work to make them work.
Therefore, it has become a bit of a PITA.
Old Jan 29, 2008 | 10:27 AM
Nahh I havent got a stock 0008 or7 anymore...they are all modded. I thinkI have a NLTS version but I wasnt sure if NJ wanted that or not. Thanks for the link Fuelie, I am sure it will help him out. The difference between the 0008 and 0007 doesnt seem to be like how the IX's are offset by 20 (hex) between the 13/14 and the 15 (i.e. 3ee62 or 3ee82).
Old Feb 1, 2008 | 01:34 PM
donour's Avatar
Easy fellas.
No, I meant is something actually _wrong_ with it. Like, did I upload a corrupted file by accident. It's my stock rom and really old.
d
Old Feb 2, 2008 | 10:48 PM
nj1266's Avatar
d
Donour,
Do you know if your rom is the most commonly used one on 04 Evo 8s? I DLed from Aktive matrix. Now I want to see if there is such thing like ECU boost mod and 2 byte load for it. Do you know if there is?
thanks
Old Feb 3, 2008 | 08:06 AM
donour's Avatar
Originally Posted by nj1266
Donour,
I don't think so. There hasn't been much interest in the rom, even though it gets downloaded pretty often. I don't think anybody has gone throught and documented the differences. I started too one time, but got got distracted.
Off the top of my head, I don't see any reason why you can't just run an '03 rom that has all the work done on it already.
d
Old Feb 3, 2008 | 08:32 AM
Donour,
thanks
Actually, there are ecu boost control, jdmmap, tephra patch and 2 byte (load, airflow) available for this Rom. It takes a bit longer for these to be found, it seems, possible due to rarity and/or the fact that this ROM is a bit "different" than others. (To elaborate on differences would best be left to the dissasemblers).
On this rom I am using Tephra's patch, logging JDMMAP, using psi-boost control w/ GM 3-Bar (work in progress) and logging 2 byte load. The only other person I know with this rom is C6CH3vo.
As far as the most common on 04s, I don't know.
Old Feb 3, 2008 | 08:38 AM
donour's Avatar
There you go!
d
Old Feb 3, 2008 | 09:16 AM
nj1266's Avatar
I was able to get 2byte load, ECU boost and ECU boost mods, JDMMAP. I do not use direct psi boost since it does not work with the pill. The only mod that I am missing is the 2 byte airflow. Anyone has it?
Old Feb 3, 2008 | 09:18 AM
nj1266's Avatar
d
So you can use an 03 rom on an 04 Evo ECU?
Old Feb 3, 2008 | 09:26 AM
donour's Avatar
EDIT: oh. I misread the question.
They are the same ECU unit, so yes I think so. I don't, but I don't see why you wouldn't want to.
d
