Hard time having ECUFlash to connect!
Old Feb 8, 2008 | 05:12 PM
90GSXDan's Avatar
Im having issues with my laptop connecting to ECUFlash. I have ECUFlash unlocker just incase and usually turn it on before I start ECUFlash. Yesterday it took me about 50 tries and close to 20 min to get the laptop to finally connect and read the ECU. Im talking about when you hit the blue ECU Button and you choose EVO IX/Eclipse, then it tells you to turn on the ignition and quickly press ok.
Any idea's? This is with my car sitting for a day or two. I tried running no ECUFlash unlocker, adjust the plug in the diagnostic port, everything! Then it finally connected after 20min of trying!
Thanks!
Old Feb 8, 2008 | 05:26 PM
nothere's Avatar
wild guess,, your battery is low, or needs a little bump
Old Feb 8, 2008 | 07:59 PM
90GSXDan's Avatar
Its a Mini battery from ETS... Its actually brand new, probably about a month on it with about 1000 miles...
Old Feb 8, 2008 | 08:17 PM
DrivinMissDaisy's Avatar
The Ecu has to warmed up before you can flash it. For some reason it can sense the temperture outside.
How cold is it out there?
Old Feb 9, 2008 | 08:27 AM
90GSXDan's Avatar
Its about 20-30* here in New York. How would I warm up the ecu? Just leave it on the ON position? Im trying to do cold start logs, so I dont want to start the car.
Thanks!
Old Feb 9, 2008 | 10:09 AM
procircuitmike's Avatar
Just throw a charger on battery 2amp charge and do your flash ecuflash is finicky with small voltage drops in your battery. Your voltage drops due to the cold weather.
Old Feb 9, 2008 | 10:10 AM
nothere's Avatar
let the car warm up, go for a long drive and then try flashing.
Old Feb 9, 2008 | 02:38 PM
90GSXDan's Avatar
Wow, nevermind, I figured out everything! Thanks!
Old Feb 9, 2008 | 05:47 PM
Jack_of_Trades's Avatar
What was it?
Old Feb 9, 2008 | 06:52 PM
90GSXDan's Avatar
yeah, It was a low amperage from the battery, so If I logged a cold start then let it sit for 2 min or so and shut it off, it connected perfectly!
