Verify some info regarding 2 byte load (Evo8)...
Old Feb 12, 2008 | 10:54 AM
turbolarry's Avatar
I'm looking to start logging 2 byte load with evoscan 2.0 and I just wanted to verify somethings before I start;
This thread refers to 94170008's
https://www.evolutionm.net/forums/sh...d.php?t=272246
... and I can still use the same code even though my interneral ROM ID is 96420008 (Evo 8), right?
I can choose to add that code to evo7base xml or to the xml that matches my ID number right?
Thanks.
Old Feb 12, 2008 | 02:15 PM
tephra's Avatar
if your not running 94170008 then you CANT use the same memory addresses and MUT_TABLE addresses as 94170008.
im pretty sure there is 2byte info for your romid floating around
Old Feb 12, 2008 | 02:18 PM
FuelsResearch's Avatar
There is thread in here titled "Most common 2004 rom" by nj1266, I posted the xml additions and what to change the tables to in there.
Old Feb 12, 2008 | 07:42 PM
turbolarry's Avatar
I did a search and found this;
https://www.evolutionm.net/forums/sh...light=96420008
... and this is where I got the idea of adding the code to evo7base (BoostEEd's response).
Can that code work for me insted with 35204 and 35205 entered into the tables?
Old Feb 13, 2008 | 05:41 AM
Yeah that thread has it too. Just add it at the end of the xml, before the <rom>. Open ecuflash (developer mode), open new tables under misc and change values to those posted in the two threads discussed here.
Old Feb 13, 2008 | 05:21 PM
turbolarry's Avatar
Got it. Thanks.
Just one more quick question before I save it all;
Does the number 35204 go into the "low bit" table and 35205 go into the "high bit" table? Or is it the other way around?
Old Feb 14, 2008 | 04:53 AM
-204 = high
-205 = low
