Question about logging fuel trims
Old Feb 16, 2008 | 02:50 PM
mountainturbo's Avatar
So I read the great writeup Sofiesleeps (?) wrote about changing MAF scaling, but I have a very n00b question.
Is it possible to do a log of fuel trims in EvoScan V1.0 without changing anything at all, or will the readings be off?
I did a log, but my fuel trims are saying 100 % for low and mid, and 107.3% for high. Is 100% meaning they're maxed out, or is that realy the ECU saying they're where they need to be? DOes that make sense?
Sorry if this question is really dumb, I searched but couldn't seem to find a simple answer.
Old Feb 16, 2008 | 05:24 PM
DrivinMissDaisy's Avatar
Evoscan does not have the right formula to log fuel trim. you need to change it. I believe it is (0.1961*x)-25. You only log low and mid. low is idle and mid is cruising at the same speed. Do both for 16 minutes and go from there.
Old Feb 16, 2008 | 06:01 PM
TouringBubble's Avatar
If your high trim isn't 100% then you need to swap the High and Low trims in the XML. They are incorrect in some versions of EvoScan.
100% is the base value in EvoScan.
