2.1 evoscan
Old Feb 18, 2008 | 11:08 AM
Terry S's Avatar
Got my email today. Something struck me as odd though. Does everyone get Map Tracer now? It appeared that it was included in 2.1 automatically.
Terry S
Old Feb 18, 2008 | 11:10 AM
EvoDan2004's Avatar
i just got mine today too.
i have been using 2.0 for a while now with no issues. other then slow logging. i bought a faster laptop but dident help much at all. so what is the updates and new features from 2.0 too 2.1
Old Feb 18, 2008 | 11:18 AM
cossie1's Avatar
Got mine aswell.
Old Feb 18, 2008 | 12:05 PM
Dapper Dan's Avatar
i got the email this morning.. tested it and its working great...
did you guys see the lcd display they sell now? im thinking about ordering one this week...
Old Feb 18, 2008 | 12:07 PM
Dapper Dan's Avatar
Mitsubishi Lancer Evolution 4/5/6/7/8/9 EvoScan Project
Mitsubishi OBDI/OBDII DataLogging Project. Supports All Mitsubishi Vehicles.
Updated: Mon Feb 18, 2007
EvoScan v2.1 Released. Download Your Copy of Evoscan v2.1 Here
EvoScan v2.1 - Release Notes:
- NEW Dataitem definitions updated... Air Temperature, Coolant Temperature, Fuel Consumption, Gear, Crank Signal, Idle Position Switch, Power Steering Switch, Air Con Switch, Air Con Relay, Inhibitor Switch, More Accurate Load Calc, Injector Duty %, LTFTs, STFTs, also many dataitems now have updated calculation functions to be more accurate.
- NEW Added ECU ID screen output for those who wish to build ecu specific data.xml lists.
- NEW OBDI/MUTI/ALDL/MMCD Diagnostic Program updated, faster/correct ecu connection, displays ECU ID.
- UPDATED Car PC Interface - use Evoscan.exe /AutoStartDatalogger to automatically begin logging on startup.
- EvoScan Website updated to include more ROMS for Subaru and Mitsubishi.
- EvoScan support helpdesk created, you can log any discussions or requests at http://www.evoscan.org/helpdesk
- NEW Gauge Template and Gauge Layout,thanks to Phil Scorgie in Australia.
Many more Gauges and Gauge Layouts to come in each newsletter.
- NEW Mitsubishi EFI/AYC/ABS USB cables available - These new usb cables support Mitsubishi the ABS and AYC ecu modules.
- NEW Awesome new AYC and ABS requestids, includes GForce, Lateral Gs, Brake Light, Steering Angle Degrees, AYC Left/Right, etc...
NEW StiScan - Built into EvoScan v2.1
All the great features of EvoScan comes to Subarus with StiScan. With the new Reflashing and Datalogging Subaru/Mitsubishi Cable you can datalog many of the cool parameters available. Currently supports SSMII 1998-2007 Subarus, at a great sampling rate of 80 samples per second. The RequestIDs and calculations were extracted from subaru ecus by me, so it should be more accurate than other dataloggers. Examples of parameters are, RPM, Speed, O2 Sensors, Injector Pulse Width, Fuel Level, Ignition Timing, Fuel Pump Duty, Gear, Exhaust Gas Temp, Knock Correction, Air/Fuel learning and correction, etc... StiScan webpage here.
NEW EvoScan StandAlone LCD ECUDataScan Display v1.0 (1994-2005 Mitsubishi) Now you can display your live vehicle parameters on your dashboard without a laptop, via the 16pin diagnostic connector and MUTII protocol. You can get the same display items as EvoScan. The dimensions of the display unit is 13cm by 5cm, and has a cable to plug into your diagnostic port.
8 parameter Mode Realtime LCD Display:
4 Parameter Mode Realtime LCD Display with Peak Hold on the right:
Default Parameters available are, RPM, Speed, Coolant Temp, Battery, Air Flow Freq, Injector Pulse Width, Injector Duty Cycle, Ignition Timing, Throttle, O2 Sensors, Intake Temperature, ISC Step, Atmospheric Press, other parameters for your vehicle available on request. You will still want a Laptop for hardcore tuning, reflashing and datalogging, but this is great being able to monitor temperatures, o2 sensors, and knock data right on your dashboard. Buy HERE only $279USD...
NEW StiScan StandAlone LCD ECUDataScan Display v1.0 (1989-2007 Subaru) Also for Subarus you can display your live vehicle parameters on your dashboard without a laptop, via the subaru 9pin or 16pin diagnostic connector. The dimensions of the display unit is 13cm by 5cm, and has cable to plug into your diagnostic port. Parameters available are: RPM, Speed, Coolant Temp, Battery, Air Flow Sensor, Injector Pulse Width, Injector Duty Cycle, Ignition Timing, Knock Retard, Throttle, O2 Sensors, Intake Temp, Alpha Correction, Atmospheric Pressure, Manifold Pressure, Wastegate Controller, Fuel Pump Duty Cycle, o2 Rich Signal, Knock Signal 1, Knock Signal 2.
NEW EvoScan Mitsubishi OBDI/MUTI/ALDL/MMCD 12pin DataLogger Cable (1989-1994 Mitsubishis)
HighSpeed USB Cable for Mitsubishi 1989-1994 vehicles. Perfect for EvoScan. Specifically supports pre 1995 Mitsubishi Vehicles with a 12 pin diagnostic port for EFI Datalogging. Mitsubishis produced in California changed to the newer
OBDII 16pin plug early in 1994, the rest followed later that year.
Buy HERE only $69USD...
NEW EvoScan Subaru Select Monitor (SSMI) 9pin/16pin DataLogger Cable (1989-1998 Subarus)
HighSpeed USB Cable for Subaru 1990-1998 SSMI vehicles. Perfect for EvoScan. Specifically supports pre 1998 Subaru vehicles with a 9 pin diagnostic port for EFI Datalogging, or if your vehicle has a 16pin obd2 style plug with metal pins in pin12 and pin13, you will need this SSMI cable.
EvoScan Supported Vehicles:
1) Supports ALL 1994-2006 USA/EUROPEAN/JAPANESE Mitsubishi Vehicles.
Mitsubishi Evo 4/5/6/7/8/9, Lancer, Eclipse, FTO, Galant, VR4, Colt, Mirage, Mivec Mirage, L400, L200, 3000GT, Pajero, Shogun, Space Runner, Grandis, Carisma, SpaceStar, SpaceGear, SpaceWagon, Sigma, Diamante, Outlander, Montero, Magna, Expo, Verada, Delica, Dodge Stratus, Eclipse, Eclipse GT/GS.
EvoScan OBDI/MUTI/ALDL/MMCD Supported Vehicles:
1989-1994 Mitsubishi Eclipse, 3000GT, GTO, Dodge Stealth, Eagle Talon, Plymouth Laser, Galant VR-4, Lancer GTI 16v, Colt, Summit & Mirage (CSM), Evo I, II & III, and other Mitsubishi vehicles fitted with a 12-PIN Mitsubishi diagnostic port.
StiScan Supported Vehicles:
1989-2007 Subaru Impreza, WRX, Sti, Legacy, Baja, Forester, Outback, US Tribeca.
Support in progress:
32) 1994-99 U.S.A. DSM - Found that it uses ISO9141-2 OBDII protocol, currently disassembling rom to check for other protocols.
33) 2000 Australian Holden VTII HSV Clubsport (support in progress) Found that it uses LS1 protocol, also earlier models use ALDL protocol. Found that this is the same as GM vehicles in the U.S.
35) Nissan (support in progress) Found that it uses CONSULT protocol
36) Honda (support in progress)
37) Australian Ford (support in progress)
38) USA Ford/USA GM (support in progress)
39) 2005/2006/2007/2008 ALL Vehicles... Protocol support for OBDII/CAN/VPW/PWM.
40) Support for Serial Com Port cables. (support in progress)
41) Support for ELM323/ELM327 Cables. (support in progress)
42) Support for Mercury/Mercruiser Speedboats. (support in progress) Found that it uses a 2pin or 4pin plug for most models.
Development in progress...
- Innovate MTS chain inputs: boost/rpm/battery voltatage/aux1-32
- Zeitronix Boost accuracy issue.
- Gauge background and transparent images functionality.
- ROMs, Gauges, and Gauge Layouts Library.
- 95/96 US Eclipse, DSM and 3000GT Vehicle Support.
- US OBDII Diagnostic Trouble Code support.
- Trigger datalogging on Throttle Position Sensor %.
Upcoming features for v3.0 include:
- WebCam and GPS Tracker - with Lap and Sector Split times.
- Monthly updates on new Gauge templates and designs.
- Support to allow faster graphing, gauges and UI response rates.
EvoScan v2.1 Released. Download Your Copy of EvoScan v2.1 Here
Old Feb 18, 2008 | 12:17 PM
evo828's Avatar
Got mine - but the update link in the message just brings me to the evoscan page and no download starts - any of you has the same behaviour?
Old Feb 18, 2008 | 12:19 PM
sharkm87's Avatar
you have to click the link in bottom of email....actually i clicked it a few times to get to right downlaod page but it eventually worked for me.
Old Feb 18, 2008 | 12:36 PM
NineWorks's Avatar
You must click at the bottom of the email, there is the link to DL the latest version.
It worked for me
Old Feb 18, 2008 | 01:20 PM
evo828's Avatar
thanks guys - that link on the bottom works fine
Old Feb 18, 2008 | 06:35 PM
mountainturbo's Avatar
Glad I found this thread, I didn't scroll all the way to the bottom of the e-mail and I was having a hard time trying to download it without repaying Guess it helps to read the whole thing
Old Feb 18, 2008 | 08:37 PM
Asmodeus6's Avatar
I did see the LCD screens. Neat idea. A bit pricey, but considering they are slightly configurable, its a cool idea for those not eager to have a laptop in the car.
I downloaded it since I eventually found the link at the bottom...
Haven't tried it yet, hope it hates me less than any of the previous version did. 2.0 simply refused to work for me. It would NOT stay connected for more than a second.
So I got awfully comfortable with logworks.
It would be stellar if this one works for me. I could see alot more which would be nice.
FYI the 2 byte RPM eval is still wrong and you need to reset it again when you install it.
Old Feb 19, 2008 | 06:56 AM
fastrob691's Avatar
Thats why I paid.
Old Feb 19, 2008 | 07:22 AM
evo828's Avatar
Originally Posted by fastrob691
Thats why I paid.
You should ask Hamish to refund - if you paid for the upgrade by mistake.
Old Feb 19, 2008 | 11:38 AM
fastrob691's Avatar
Its all good, this guy does a ton of work for not alot of money, so I look at it like money well spent.
Old Feb 19, 2008 | 11:42 AM
idriveanevo's Avatar
i installed mine today, but now when i try to log, it says it cannot find com1. what do i have to change?
