EVOSCAN 2.1 Maptracer Problems!
Old Feb 27, 2008 | 03:07 PM
2k4EvoVIII's Avatar
Originally Posted by kreionic
it didnt work for me either. Not to sure. Like I said logged and ran a 08 through yesterday and was fine
Can you tell me everything you were logging in the logs that worked with Maptracer? Maybe there is something im not logging that i need to for it to work?
Chris
Old Feb 27, 2008 | 03:44 PM
kreionic's Avatar
yeah all the normal stuff. I didnt find 2 byte rpm or aiflow by the time I needed it. So it was tps, 2 byte load, timing, a/f, knock, rpm, IPW, IDC
I dont think it has to do with not logging something
Old Feb 28, 2008 | 12:53 PM
2k4EvoVIII's Avatar
Evoscan got back to me on this problem. Below you will see what they posted on the ticket. So hopefully everything will be fine in 2.2.
"Thanks I'll take a look, and fix it for Evoscan v2.2 being released soon."
Old Apr 27, 2008 | 08:15 PM
Hcaruso4's Avatar
I am using evoscan 2.2 and the exact same thing is happening to me and I cant figure out why. Values will load in the bottom section of map tracer when i load my xml file but nothing will come up in the top grid no matter what i check off on the left. Can anyone help
Old Feb 7, 2009 | 03:20 PM
evodziobak's Avatar
I have the same problem in evoscan 2.5
Old Feb 8, 2009 | 06:34 PM
b16a95eg's Avatar
me too in evoscan 2.5
Old Feb 8, 2009 | 07:18 PM
raasfaas's Avatar
I was having the same problem the other day with 2.5 but after messing around with it I figured out that you have to have loadcalc checked for the maptracer to work (even if you use MUT 2byte or 1byte load for tuning)
Note: I'm sure you all know this already...loadcalc needs to have AFRMAP and battery selected for it to work and they also have to be above it in the list.
Hope this solves it.
Old Feb 8, 2009 | 07:30 PM
b16a95eg's Avatar
i'll give that a try tomorrow, thanks!
Old Feb 8, 2009 | 07:37 PM
b16a95eg's Avatar
i have another little question, how come on my realtime logging graph, there is like from 0-3000 in 500 intervals going up the left side? i though the numbers were supposed to be smaller, i just downloaded it today so i dont really know anything about it
Old Feb 9, 2009 | 02:09 AM
evodziobak's Avatar
yeah that solved the problem. thanks. I tough the load will just be logged anyway but I guess not :-) the other thing is that in map tracer I only see loads from 0 -100 . can't see the rest of load like in my map where it goes up to 260. do you know why is that?
Old Feb 9, 2009 | 07:13 AM
raasfaas's Avatar
Well I've never really used the realtime logging before so I dont know much about it, I'll see if I can mess around with it after work today and let you know.
evodziobak: you have to load your current XML and HEX/BIN file for it to show properly. Right click on anywhere in the bottom table and then select "load xml/hex file." Make sure you select the xml file associated with your romid and the hex file that is currently running on your ecu.
Hope that helps.
Old Feb 9, 2009 | 07:17 AM
b16a95eg's Avatar
if i dont need to use real time logging i wont, i was just trying to see my knock, and with the huge intervals on the side i couldnt, you can kinda zoom in i think by dragging your mouse, but i'm not really sure what it does. it does zoom in to smaller numbers but then my knock graphs look weird, like it showed up as like 30, and i hope its not right lol
Old Feb 9, 2009 | 12:57 PM
b16a95eg's Avatar
i still couldnt get the map tracer to work, it wouldnt let me right click the graph and download my .hex ( i think thats what the name was) it just does nothing....
Old Feb 9, 2009 | 12:58 PM
MR Turco's Avatar
I posted this in the 2.6 thread but it might get answered here. Here is my problem:
I have to be doing something wrong. I for the life of me cannot get maptracer to work in 2.5 or 2.6 beta 7. I did notice in beta 7 the autoload is looking in an obscure folder for my .xml. I have one in there but it was like an old one that doesn't work. I replaced it with a working one and maptracer seems to load properly but when i click on parameters the top table displays nothing.
Is there a way to change where it looks to autoload the .xml? Am i doing something wrong?
Old Feb 9, 2009 | 03:19 PM
b16a95eg's Avatar
i figured out that when the numbers were up to 3000 it was because of mut 2 byte load. if i dont have that selected its normal
