changing roms
Old Mar 19, 2008 | 06:36 AM
nothere's Avatar
changing roms
I have the old 2003 evo original rom # 9417008, I see that there have been some course corrections on it.
94170014 &
94170015
How do I implant the newer roms?
Old Mar 19, 2008 | 07:30 AM
PVD04's Avatar
I actually did this just this week. Just copy all of your changes over to the base map (fuel, timing, idle, injector scaling and latency, boost cut, IMMOBILIZER, etc) and then write to the ECU. If you changed other tables you'll want to get those changes copied over as well.
-Paul
Old Mar 20, 2008 | 06:24 AM
nothere's Avatar
I assume the changes are made in ecuflash, how do I get the new rom into my ecuflash flash/working screen
or do I make the changes in the romdata screen?
Old Mar 20, 2008 | 07:14 AM
PVD04's Avatar
You have to download the stock map. Aktivematrix has a bunch of them available for download. You open that map in ecuflash and change all the necessary tables. DO NOT FORGET THE IMMOBILIZER. It's an easy one to forget as you never have to change it.
-Paul
Old Mar 20, 2008 | 08:08 AM
bnice01's Avatar
one more good place to find roms is here
http://forums.openecu.org/
Old Mar 20, 2008 | 11:35 PM
codgi's Avatar
Don't forget to ensure you have a copy of the original rom in case you need to roll back to that.
