ECU disassembling?
Old Apr 5, 2008 | 02:05 PM
Jack_of_Trades's Avatar
So you're saying a higher resolution map in a stand-alone with greater processing speeds can't make use of the larger mapping? I highly doubt that. Granted we don't need a 32X32 map but adding 5 or 6 more columns on each axis would definitely do wonders. Especially for the guys now exceeding the 340 loads and revving to 10K RPM. Take a look at their scaled maps and tell me they wouldn't benefit greatly with greater resolution, especially for cruising.
Old Apr 5, 2008 | 02:19 PM
nothere's Avatar
I agree that with expanded higher load columns it would be nice to have more available.
What I am saying is with my aftermarket computer I was able to see that it only hit a few cells on its way to max load. There just isn't time. The car jumps many load cells in an instant and can only keep up by anticipating. You can see the same thing on the map trace on the stock ecu.
And I wouldn't be surprised to find that the stock ecu has more built in adjustments to refine its position/ output than the aftermarket.
Old Apr 6, 2008 | 05:42 AM
burgers22's Avatar
I have done a bit of work on larger maps for my Evo VII, I 've got the fuel maps, the RPM and load scales, the code pointers and map headers pretty much done, but have not tested it and really don't have the time for it right now. If anyone wants to look at them, let me know.
MB
Old Apr 6, 2008 | 09:22 AM
JoeBee's Avatar
Originally Posted by JoeBee
Already read this thread (and post in it), but there is no information about the Switch "auto" position.
I have logged this morning all that Processor ports that where possible through mut, but no BIT change occure. I have found the change at PJDR Bit 0 for the led.
Now I am a little bit confused, because tephra is using it in his patches.
Where is this Bit? (LOL the search for ONE Bit in a world of Terabytes)
@tephra
Can you help me out?
I have try some variables, but none find yet.
Old Apr 6, 2008 | 03:46 PM
tephra's Avatar
you want to know what variable to log to see the auto switch being held down?
romid?
Old Apr 7, 2008 | 12:26 AM
JoeBee's Avatar
romid?
Yes.
My ROM ID is a little bit rare EVO VII 99860002 but you can give me the information for the rom 90550001 which you always has patched. I think I can transform this to my rom ID.
Old Apr 7, 2008 | 01:37 AM
tephra's Avatar
unlikely, can you email me the ROM? i can do some basic disasm on it to find what you need!
any particular reason you want to log that?
Old Apr 7, 2008 | 08:06 AM
JoeBee's Avatar
Not only logging. I wand to use ist for a patch as an input.
When you give me your Email (PM?) I can send you the original ROM.
Old Apr 7, 2008 | 10:13 AM
JoeBee's Avatar
This begins to p... me up.
After reviewing much of code I think I have found some canidates/variables.
I have logged this variables tonight but nothing found.
@tephra
It is enough when you name the variable that you have used in your patch in the Rom ID 90550001 then I can found it in my Rom.
Old Apr 7, 2008 | 03:11 PM
tephra's Avatar
lol - its painful sometimes
email is tephra @ <dont include this bit, just avoiding spam> gmail <or this bit> .com
Old Apr 8, 2008 | 02:29 AM
JoeBee's Avatar
Mail is on its way.
Old Apr 8, 2008 | 10:27 AM
JoeBee's Avatar
Jabba Dabba Dooooo
I have found the variable.
Old Apr 8, 2008 | 03:59 PM
tephra's Avatar
cool - so you dont need me to look anymore?
Old Apr 9, 2008 | 03:18 AM
JoeBee's Avatar
At the moment I don't need you.
...at the moment.
Thank you for your help.
Old Apr 27, 2008 | 11:48 AM
JoeBee's Avatar
One more question.
How is this 'Rear O2 Simulator' patch realized?
Is it simply a copy of the front signal to the rear adresses, or is there a timeshift needed?
Have somebody a log of front and rear O2 Sensor Voltage with a working Catalyst?
