Timing vs. AFR in relation to making power
Old Apr 10, 2008 | 10:31 PM
  #31
bboypuertoroc's Avatar
Veteran: Army
Another question (this one might be somewhat noobish)... how can I add in more load cells? Not beyond 300, but in between? Right now it's every 20 (200, 220, 240, etc), and I can see it being a bit of a pain in the *** to get an accurate AFR set when I gotta take a wild guess as to which cells to modify. For instance, if I want to change the AFR at 4500rpms and it's at 250 load, do I change the 240 cell, 260 cell, both, what?
Old Apr 10, 2008 | 10:42 PM
  #32
tephra's Avatar
yeah edit the axis in ecuflash (click on what you want to change and press '=').
you cant "add" cells easily, but you can relabel other cells.
most people remove load 20-40 because all the fuel/timing cells are identical in this range.
Old Apr 10, 2008 | 11:58 PM
  #33
codgi's Avatar
Car is idles at 30-40 so better to knock out 20. Also gotta be careful here since rescaling these tables affects at least 2 other tables which a quick search in this forum will show.
Old Apr 11, 2008 | 09:55 AM
  #34
Mr. Evo IX's Avatar
You can change the scale but you can't add map resolution.. The fuel table on a IX will always be 15x20. You can rescale the cells.
The ECU interpolates between the cells so if you have 6 at 220 and 8 at 240 then the ECU will read a 7 at 230 even though it's not visible. Sometimes you have to modify one, sometimes both.. depends on what your trying to do. Overall try to keep the entire landscape smooth.
Old Apr 11, 2008 | 12:41 PM
  #35
Veteran: Army
OK, thanks.
Old Apr 11, 2008 | 01:29 PM
  #36
JohnBradley's Avatar
Other than it affecting other tables possibly for the worse, you can drop the 20-30 like Dave said since they dont affect idle fueling anyway and the car isnt really there other than idling. It will interpolate the value between 10 and 40 and since they are the same value anyway it would be okay if it was idling open loop.
Old Aug 20, 2008 | 04:48 AM
  #37
Charlie_B's Avatar
^^ what 2 tables? I know it affects the low octane map, but what else?
Also, it seems like the way to go is to lean out a little as boost tapers off. What if your lucky enough to peak/hold 21psi to redline? I peak at 21-22 and hold it to redline, using an old school Greddy Profec B. I assume that I should shoot for a consistent AFR with that being said. Is that correct?
My goal is 12.5 tapering to 11.7 at peak torque, and hold it to redline. Im running 91 (E10). And have been running 11.5 tapering to 11.0 at redline. With 2* peak torque timing tapering up to 12-13* or so at redline. Id guess that I will have to decrease timing mostly up top. I dont have an EGT gauge. Do you guys think that I getting into unsafe EGT land with these low numbers. Or is it all relative? As long as your not ultra conservative with AFR or timing, youre good?
Sorry for bringing it back from the dead...
Old Aug 20, 2008 | 09:25 PM
  #38
codgi's Avatar
Take a read here for those tables:
https://www.evolutionm.net/forums/sh...st+Enhancement
Old Aug 21, 2008 | 04:46 AM
  #39
Charlie_B's Avatar
thanks. I had missed that one. Im just hoping that my rom has those tables defined so I can adjust them for my current load/rpm scaling.
APEvoVIII
10
Oct 18, 2015 02:19 AM
awdordie
Apr 2, 2012 10:31 PM
jrhonda
Jun 14, 2010 05:04 PM
Bugermass
70
Apr 30, 2010 11:02 PM
nj1266
Oct 13, 2007 04:09 AM
