Why do you need a Resistor with the GM 3 Port?
Old Apr 20, 2008 | 07:56 AM
racer135's Avatar
What is the resistor in the GM 3 Port Pigtail used for? What happens if it does not have it or if it is another value. It is a 12V solenoid so why is it needed.
Will this mod through a CEL?
Old Apr 20, 2008 | 08:55 AM
recompile's Avatar
It's used to limit current draw from the ECU
Old Apr 20, 2008 | 03:29 PM
tephra's Avatar
yeah apparently it reduces the amount of current the soleniod can draw
electronics are about volts AND amps
it wont throw a CEL
Old Apr 20, 2008 | 04:04 PM
kkarim's Avatar
if i'm not mistaken, the GM solenoid's resistance is 10 ohm less than the stock one. so to stop the current raising with the GM, you add a 10ohm res, so the ecu sees the same load.
