Accell Enrichment News
Old May 22, 2009 | 03:37 AM
shadow1's Avatar
Originally Posted by dude
This sounds more like an artifact of having lean spool disabled. Pretty common condition under tip-in with it disabled.
Interesting thought, but I tune with lean spool enabled. I may adjust the lean spool engagement point since my stock turbo spools a lot sooner with my Buschur head.
Old Jun 3, 2009 | 07:37 PM
Appauldd's Avatar
94170015 Please.
Old Jun 3, 2009 | 09:20 PM
RoadSpike's Avatar
Originally Posted by Appauldd
94170015 Please.
I think this is the right one.
<table name="Accel Enrich Base vs Engine Temp" category="Fuel" address="3856" type="2D" level="2" scaling="uint8">
<table name="Engine Temp" address="67a2" type="X Axis" elements="8" scaling="Temp"/>
</table>
<table name="Asynch_Acell_Enrichment" category="Fuel" address="1654" type="2D" level="1" scaling="uint16">
<table name="X" type="Static Y Axis" elements="5">
<data>pause_period</data>
<data>min_TPSdelta</data>
<data>Max_pulsewidth</data>
<data>idle_TPSRange</data>
<data>after_engine_start_addition</data>
</table>
</table>
<table name="Asynch_VS_TPSDELTA" category="Fuel" address="38a2" type="2D" level="1" scaling="uint8">
<table name="X" type="Static Y Axis" elements="9">
<data>0</data>
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
<data>5</data>
<data>6</data>
<data>7</data>
<data>8</data>
</table>
</table>
<table name="Asynch_TPS(Rpm) Limit" category="Fuel" address="38b2" type="2D" level="1" scaling="WGDuty">
<table name="X" address="6406" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="Asynch_Accel_vsRPM" category="Fuel" address="38d0" type="2D" level="1" scaling="uint8">
<table name="X" address="6406" type="Y Axis" elements="15" scaling="RPM"/>
</table>
Lemme know ok?
Old Jun 3, 2009 | 09:36 PM
Appauldd's Avatar
Works like a champ.....Thank you very much.
Now I have to figure out exactly what these do.
Old Jun 3, 2009 | 09:43 PM
RoadSpike's Avatar
Asynch_VS_TPSDELTA is like an instant boost to fuel when accelerating. The values seem to be how fast you open the throttle from slow to fast. Accel Enrich Base vs Engine Temp just seems to be a multiplier the rest sorta speak for themselves
Old Jun 4, 2009 | 12:02 PM
honki24's Avatar
So is there a defined "accel enrichment" for the VIIIs with a MAS? 94170014 in specific? I can't follow all of this lingo.
Appauldd's Avatar
Yes.
Old Jun 4, 2009 | 12:34 PM
nonschlont's Avatar
I tried adding the definitions from post 1 to my 88590015, and got a parse line error. Checked the definition, and looked ok to me... Is there something missing from the top definition? "table name="? Is this for a different 015?
</table>
</table>
<table name="Asynch_VS_TPSDELTA" category="Fuel" address="32b6" type="2D" level="1" scaling="uint8">
<data>0</data>
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
<data>5</data>
<data>6</data>
<data>7</data>
<data>8</data>
</table>
</table>
<table name="Asynch_TPS(Rpm) Limit" category="Fuel" address="32c6" type="2D" level="1" scaling="WGDuty">
<table name="X" address="6c26" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="Asynch_Accel_vsRPM" category="Fuel" address="32e4" type="2D" level="1" scaling="uint8">
</table>
Old Jun 4, 2009 | 12:40 PM
MR Turco's Avatar
I had the same problem.
Old Jun 4, 2009 | 12:46 PM
Appauldd's Avatar
You are missing some lines from this.
</table>
</table>
This needs to be added.....but the address is different for your rom.
Old Jun 4, 2009 | 01:04 PM
RoadSpike's Avatar
</table>
</table>
Address is 1254
<table name="Asynch_Acell_Enrichment" category="Fuel" address="1254" type="2D" level="1" scaling="uint16">
</table>
</table>
Old Jun 4, 2009 | 02:52 PM
mitsuv's Avatar
Nice job, very interesting, can't wait for the 90550001
Old Jun 4, 2009 | 03:06 PM
nonschlont's Avatar
thanks guys! good lookin out... Is there any particular order these need to be in? Im assuming I can just add
</table>
</table>
ON TOP OF THIS and then, the rest of the patch...
</table>
</table>
Thanks again!
Old Jun 4, 2009 | 03:29 PM
RoadSpike's Avatar
</table>
</table>
</table>
</table>
Thanks again!
No it replaces the below line not an addition so...
</table>
</table>
INSTEAD OF THIS and then, the rest of the patch...
</table>
</table
Old Jun 5, 2009 | 10:18 PM
nonschlont's Avatar
thanks.
