Ok why the F wont evo scan work right??
Ive done 3 3rd gear pulls but whenever i tried to look at them, it shows me almost no data.
And also, i hooked up my aem wide band, blue to pin #2 and pin #5 to ground. Hooked it up to com 3, and it wont log it
Can some one just tell me how i get it to actually give me data???
im getting so irritated with this.
The only data it will give me is in the load cell "0"
i have seen a few post of people showing connection ok but no data. Sounds like a hardware flow control issue. As for the wideband are you able to use hyperterminal working? I dunno man hope it works out for you.
there is a defect in evoscan version 2.1 i have spoken to hamish about this and the newer version that is comming out soon v2.2 will work. for now reverting to an older version of evoscan will also fix the problem. let hamish know via email what is going on and he will hook you up. this has nothing to do with your comp though as long as its evoscan 2.1 that your having the trouble with
i am using 2.2 as well but it works fine for me, normally the log to file button is already checked under the file menu. to start the log i just hit start log. does it show you any information when you view realtime graphs... what version of tactrix are you using
Ummmmm i just ordered it a week or two ago, so im not sure
