Help Needed: 2byte setup for Evo 7
Old May 4, 2008 | 03:25 AM
erggy's Avatar
I did some searching and found the instructions on how to setup 2byte for both Evo8/9s (below)... now I'm still missing some information which I wasn't able to find on the webboard.... can anybody pls help
Car: JDM Evo7
ROM: 98640014
2byte load
MUT 00 = 885C
MUT 01 = 885D
MUT 3D TABLE ADDRESS = 2E9E0
Missing information below
<table name="2 byte load high bit" address="885C????" category="Misc" type="1D" level="1" scaling="uint16" />
<table name="2 byte load low bit" address="885D????" category="Misc" type="1D" level="1" scaling="uint16" />
</rom>
Save the changes.
3.) Open ECUFlash. Scroll down to the Misc section and you'll see two new entries: "2 byte load high bit" and "2 byte load low bit."
4.) Enter ????? as the value for "2 byte load high bit."
Enter ???? as the value for "2 byte load low bit."
5.) Save the ROM file. Flash the ROM.
Old May 4, 2008 | 04:44 AM
sub7's Avatar
<table name="RequestID00" category="MUT" address="2e9e2" type="1D" level="1" scaling="Hex16"/>
<table name="RequestID01" category="MUT" address="2e9e6" type="1D" level="1" scaling="Hex16"/>
In ECUFlash, open your MUT->RequestID00, change the default e7 value from 87B3 to 885C (and RequestID01 too).
Then flash it.
Old May 4, 2008 | 06:18 AM
burgers22's Avatar
Request ID00 should be 885C, you need to enter it as 0x885C
Request ID01 should be 885D, you need to enter it as 0x885D
MB
Old May 4, 2008 | 09:53 PM
erggy's Avatar
Thank you very much, didn't expect to find many evo7 owners on the board
However, is it "Hex16" or "uint16" to be used as the scaling below?? Thank you.
Old May 4, 2008 | 10:28 PM
Wicked E's Avatar
Hex16
-E
Old May 5, 2008 | 01:48 AM
erggy's Avatar
guys, I did use the updated XML with the recommended lines already (used the updated XML from burgers on OpenECU forum). However, even before I tried to update REQUEST ID00 and 01 to be 885C and 885D I checked the RPM and Load axes (x and y axes) but the numbers are weird. Any reason for this?
T_T
Old May 5, 2008 | 07:32 AM
sub7's Avatar
Care for a screenshot?
