Low load numbers
Old May 23, 2008 | 10:07 AM
Nuked's Avatar
Low load numbers
I have a IX with a BR3065 turbo. I am hitting 280-270 load (2byte) from peak boost to redline. 26psi. Shouldnt this be a higher number? My stock IX turbo was hitting over 300 at 28psi peak and even with the taper to 21psi it was still at 270 load at redline. What would cause this?
Thanks,
SQ
Old May 23, 2008 | 02:13 PM
Asmodeus6's Avatar
At 25.5psi I am at 270-280 load. (3076R)
But I also have maft pro. And it drops the load about 20-40.
Old May 23, 2008 | 03:31 PM
lemmonhead's Avatar
im on stock evo 9 turbo, 24psi hitting 260-270 load
Old May 23, 2008 | 03:50 PM
dryad001's Avatar
Hmm, I hit about 320 or so
Old May 23, 2008 | 05:18 PM
turboracer's Avatar
hit 300 load on 32 psi pull 3076r
Old May 23, 2008 | 05:21 PM
Mellon Racing's Avatar
with a stock unmolested mas at 30psi on the HTA 35R I see 335-340kpa, now that I've epoxied the screen around the sides so it isn't sucked into the turbo it's hitting 380kpa and holding it there (that is the max) 93 octane pump gas only
Old May 23, 2008 | 05:30 PM
Asmodeus6's Avatar
Holy off the chart mellon. I'd love to see your load map. I think that MAF is ready for retirement.
Old May 23, 2008 | 05:34 PM
dryad001's Avatar
No kidding, I sucked in a MAF screen with a 3065 at 27psi
Old May 23, 2008 | 05:36 PM
RazorLab's Avatar
Remember intake pipes and filters can mess with the MAF, thus showing different load.
Old May 23, 2008 | 05:37 PM
Asmodeus6's Avatar
Damage? Or did it just detach and catch?
Old May 23, 2008 | 05:58 PM
here's what my load/rpm looks like when I shift to 4th:
Code:
RPM	LoadMUT2Byte
5781.25	295.625
6062.5	324.0625
6218.75	340.3125
6250	349.6875
6187.5	359.0625
6312.5	373.75
6343.75	376.5625
6375	379.6875
6406.25	379.6875
6468.75	379.6875
6500	379.6875
6531.25	379.6875
6625	379.6875
6625	379.6875
6656.25	379.6875
6718.75	379.6875
6750	379.6875
6781.25	379.6875
6843.75	379.6875
6875	379.6875
6906.25	379.6875
6968.75	379.6875
7031.25	379.6875
7031.25	379.6875
7062.5	379.6875
7125	379.6875
7187.5	379.6875
7218.75	379.6875
7250	379.6875
7312.5	379.6875
7343.75	379.6875
7375	379.6875
7406.25	379.6875
7468.75	379.6875
7500	379.6875
7562.5	379.6875
7562.5	379.6875
7593.75	379.6875
7656.25	379.6875
7687.5	379.6875
7687.5	379.6875
7718.75	379.6875
7750	379.6875
7781.25	379.375
7812.5	379.375
7843.75	378.125
7875	375.3125
Old May 24, 2008 | 12:21 AM
Nuked's Avatar
Ok, went to the track tonite. Logs showed 300 load at 25psi. Only change I did to the car was reflashed it to change the rev limiter. I am thinking it might have had something to do with my fuel trims being all wacked out, car runs leaner upon reset of trims, hence higher load? Sound plausible? Also the car hit 54lbs/min and 2650hz airflow, most I have seen yet out of this turbo.
Lastly, I noticed my logs have rpm topping out at 7968. I know this is not accurate, as I missed a gear on a run and pegged the rev limit of 8500. Any ideas?
SQ
Old May 24, 2008 | 01:05 AM
Asmodeus6's Avatar
2 byte rpm?
Old May 24, 2008 | 04:57 AM
tephra's Avatar
255 * 31.25 = 7968.75 thats why you top out @ 7968
for most its not a problem, but for high revving cars you should log 2byte rpm
Old May 24, 2008 | 09:04 AM
Nuked's Avatar
Yeah I need to start logging 2byte. I tried it once and the number was all out of whack, I will look into it today. I am also going to pull the mass air out and check the mesh as Mellon suggested.
Thanks all,
SQ
