Data Log Lab
Old May 26, 2008 | 06:33 PM
ineedparts's Avatar
Data Log Lab
What do I need In Order to function it properly
evo ix se
What do i need to download?, Change Things around..?
Please
ANY HELP IS APPRICIATED.........
Old May 26, 2008 | 06:57 PM
ineedparts's Avatar
Anyone...........................................
Old May 26, 2008 | 08:40 PM
ineedparts's Avatar
evo m got mean ppl.
you guys dont like helping out for ****.
Old May 26, 2008 | 11:53 PM
RazorLab's Avatar
It's memorial day
here is a semi-recent def file from my desktop:
[DataLogDefinition]
Name=EvoScan 0.97
FileExtension=csv
FileIDTextLinesBefore=0
FileIDTextColumnsBefore=0
FileIDText=LogID
ColumnHeadersLinesBefore=0
DataLinesBefore=1
DelimiterAsciiCharacter=44
Version=1.0
Comments=EvoScan Definition
[Column]
Name=LogID
Description=Log ID
ColumnTitle=LogID
DataItemID=51
Type=1
ColumnDecimalPlaces=0
DisplayDecimalPlaces=0
[Column]
Name=LogEntryDate
Description=Log Date
ColumnTitle=LogEntryDate
DataItemID=51
Type=1
[Column]
Name=LogEntryTime
Description=Log Time
ColumnTitle=LogEntryTime
DataItemID=51
Type=1
[Column]
Name=LogEntrySeconds
Description=Log Seconds
ColumnTitle=LogEntrySeconds
DataItemID=63
Type=1
ColumnDecimalPlaces=8
DisplayDecimalPlaces=5
[Column]
Name=Accel Enrich
Description=Accel Enrichment
ColumnTitle=AccelEnrich
DataItemID=59
Type=1
DisplayDecimalPlaces=2
[Column]
Name=C Temp
Description=Coolant Temperature
ColumnTitle=CoolantTemp
DataItemID=23
Type=1
ColumnDecimalPlaces=2
[Column]
Name=RPM
Description=Engine RPM
ColumnTitle=RPM
DataItemID=3
Type=1
[Column]
Name=TrimHigh
Description=Fuel Trim - High
ColumnTitle=FuelTrim_High
DataItemID=58
Type=1
ColumnDecimalPlaces=4
DisplayDecimalPlaces=4
[Column]
Name=TrimLow
Description=Fuel Trim - Low
ColumnTitle=FuelTrim_Low
DataItemID=57
Type=1
[Column]
Name=TrimMed
Description=Fuel Trim - Med
ColumnTitle=FuelTrim_Middle
DataItemID=56
Type=1
[Column]
Name=IDC
Description=Injector Duty Cycle
ColumnTitle=InjDutyCycle
DataItemID=13
Type=1
ColumnDecimalPlaces=5
DisplayDecimalPlaces=3
[Column]
Name=O2 Feedback
Description=O2 Feedback Trim
ColumnTitle=O2FeedbackTrim
DataItemID=55
Type=1
[Column]
Name=O2
Description=O2 Sensor
ColumnTitle=O2Sensor
DataItemID=7
Type=1
[Column]
Name=TPS
Description=TPS
ColumnTitle=TPS
DataItemID=17
Type=1
[Column]
Name=AirFlow
Description=Air Flow
ColumnTitle=AirFlow
DataItemID=81
Type=1
[Column]
Name=Air Temp
Description=Air Temperature
ColumnTitle=AirTemp
DataItemID=31
Type=1
[Column]
Name=Air Vol
Description=Air Vol
ColumnTitle=AirVol
DataItemID=83
Type=1
[Column]
Name=Baro
Description=Barometer
ColumnTitle=Baro
DataItemID=5
Type=1
[Column]
Name=ISCSteps
Description=ISC Steps
ColumnTitle=ISCSteps
DataItemID=54
Type=1
ColumnDecimalPlaces=1
DisplayDecimalPlaces=1
[Column]
Name=Knock
Description=Knock Count
ColumnTitle=KnockSum
DataItemID=30
Type=1
[Column]
Name=WGDC
Description=Waste Gate Duty Cycle
ColumnTitle=WGDC
DataItemID=10
Type=1
[Column]
Name=Timing
Description=Timing Advance
ColumnTitle=TimingAdv
DataItemID=21
Type=1
[Column]
Name=Battery
Description=Battery Voltage
ColumnTitle=Battery
DataItemID=22
Type=1
[Column]
Name=EGRTemp
Description=EGRTemp
ColumnTitle=EGRTemp
DataItemID=51
Type=1
[Column]
Name=OCTNumber
Description=OCTNumber
ColumnTitle=OctaneFlag
DataItemID=53
Type=1
[Column]
Name=AFRMAP
Description=AFRMAP
ColumnTitle=AFRMAP
DataItemID=70
Type=1
[Column]
Name=Speed
Description=Speed
ColumnTitle=Speed
DataItemID=24
Type=1
[Column]
Name=MDP
Description=MDP (Map)
ColumnTitle=MAP
DataItemID=71
Type=1
[Column]
Name=LoadCalc
Description=LoadCalc
ColumnTitle=LoadCalc
DataItemID=82
Type=1
[Column]
Name=AFR
Description=AFR
ColumnTitle=WideBandAF
DataItemID=73
Type=1
DisplayColour=99
DisplayLineWidth=3
[Column]
Name=JDMMAP
Description=Boost Loggin
ColumnTitle=JDMMAP
DataItemID=78
Type=1
[Column]
Name=2Byte Load
Description=LoadMUT2Byte
ColumnTitle=LoadMUT2Byte
DataItemID=25
Type=1
[Column]
Name=AirFlow2byte
ColumnTitle=AirFlow2Byte
DataItemID=52
Type=1
[Column]
Name=WGDCCorr
Description=WGDCCorr
ColumnTitle=WGDCCorr
DataItemID=53
Type=1
Offset=50
[Column]
Name=LoadError
Description=LoadError
ColumnTitle=LoadError
DataItemID=54
Type=1
Offset=50
Name=g/Rev
Description=Grams per Rev
ColumnTitle=gRev
DataItemID=57
Type=1
DisplayFactor=10
Offset=0
[Column]
Name=lb/min
Description=Compressor lb per minute
ColumnTitle=lbs/min
DataItemID=58
Type=1
DisplayFactor=1
Old May 27, 2008 | 12:35 AM
ineedparts's Avatar
BRYAN, thank you so much man!
with that file you just send me.... how do i load it onto DataLogLab...?
plz! thanks
reboundicon
28
Jan 31, 2018 10:47 AM
willdatrill2007
Oct 9, 2016 09:01 PM
BogusSVO
Dec 1, 2012 01:15 PM
Echelon Auto
May 30, 2012 01:52 PM
Sir Lancelot
For Sale - Part Outs
58
Feb 24, 2008 08:11 PM
