Installed 880's and now my FuelTrim_High is off.
Old May 26, 2008 | 09:29 PM
BCOZEVO's Avatar
After installing my PTE 880's I rescaled my injectors and my FuelTrim_High is at 94.53125 in my logs.
I am attaching a log from my last run. Mods at the bottom and I am at 28PSI.
Yes I know my AFR's are all jacked in the top end right now, I have not had a chance to tune it yet.
I also want to get this FuelTrim_High issue out of the way first.
Thx
File Type: zip
Old May 27, 2008 | 02:19 AM
tephra's Avatar
I didn't look at your log, but it sounds like you expect the fueltrims to have an affect @ WOT?
They don't - so ignore them
Old May 27, 2008 | 06:24 AM
TouringBubble's Avatar
Are you sure that your high and low trims aren't mixed up? Later versions of EvoScan have halfway fixed the issue ... if your low is 100 and your high is moving, you need to swap them in the XML.
Old May 27, 2008 | 06:53 AM
jcsbanks's Avatar
94 is trivial anyway.
