-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Installed 880's and now my FuelTrim_High is off. (https://www.evolutionm.net/forums/ecu-flash/347795-installed-880s-now-my-fueltrim_high-off.html)
BCOZEVO May 26, 2008 09:29 PM
1 Attachment(s)
After installing my PTE 880's I rescaled my injectors and my FuelTrim_High is at 94.53125 in my logs.
I am attaching a log from my last run. Mods at the bottom and I am at 28PSI.
Yes I know my AFR's are all jacked in the top end right now, I have not had a chance to tune it yet.
I also want to get this FuelTrim_High issue out of the way first.
Thx
tephra May 27, 2008 02:19 AM
I didn't look at your log, but it sounds like you expect the fueltrims to have an affect @ WOT?
They don't - so ignore them :)
TouringBubble May 27, 2008 06:24 AM
Are you sure that your high and low trims aren't mixed up? Later versions of EvoScan have halfway fixed the issue ... if your low is 100 and your high is moving, you need to swap them in the XML.
jcsbanks May 27, 2008 06:53 AM
94 is trivial anyway.
