Flash Counter
Old Jun 6, 2008 | 10:09 AM
tinywrex's Avatar
things are really simple, no hidden bits or bytes
How i would do it:
The flash counter is updated on the PC software side and transferred to the ROM
so in rough lines it would work like this:
each rom will have its "license", database kept on the PC.
flash procedure starts
-check "licence"
-read flash counter from ROM
-compare against counter stored in PC database, PC database ALWAYS has correct number so you cant fiddle with it
-increase counter
-rom file update
-physical flash
rinse & repeat
Old Jun 6, 2008 | 10:22 AM
JohnBradley's Avatar
I am over 2500 now and going strong. I stopped counting to be perfectly honest so it might be over 3000. Alot at any rate.
Old Jun 6, 2008 | 04:43 PM
tephra's Avatar
Tiny - this isn't the ECU keeping track of the number of flashes its the software.
anyways ECUTek might do this - but who cares, ECUTek is a rip and noone uses it anymore...
Old Jun 11, 2008 | 11:53 PM
tinywrex's Avatar
yep, thats what i am saying
There could be a possibility that the ecu keeps track of flashes, for example the actual kernel that does the comms/flashing has a simple code fragment to update a counter.
In any case, if the OEM manufacturer wants to do it, they most certainly can do it.
newpassport
Jun 10, 2012 07:22 PM
S2K2EVO
Nov 2, 2011 12:52 PM
mramdirtb
Nov 9, 2007 10:22 AM
cage-anator
Northwest Region
11
Mar 16, 2007 06:45 AM
mooreboost
25
May 14, 2005 03:52 PM
