Can Fuel Trims be Perfect?
Old Jun 13, 2008 | 07:02 PM
Inprogress's Avatar
Is that normal?
Old Jun 13, 2008 | 07:54 PM
Jack_of_Trades's Avatar
Originally Posted by Inprogress
Yeah, I do sometimes get this weird idle dip, not sure what it's from though.
For example, when I start the car in the morning and put it into reverse to pull out of the garage, the rpms will fall down to the 700ish range and afr's will go full lean but after a few seconds it will come back to normal and idle rock solid. Is this occurring because of the fuel trims?
Its because your car is running solely on the open loop tables when you first take off. Log the issue and see what your AFR's are doing when it hiccups and the RPM/LOAD range, mine would go way lean (17+ AFR) and it would bog a bit. I adjusted the open loop tables in the problem areas and never had the issue since. Since its in open loop, there is no fuel trim, just the table settings which are set in stone.
Old Jun 13, 2008 | 10:23 PM
nj1266's Avatar
I am getting the same problem as inprogress. When I pull inot my inclined driveway and give the car gas and then come to an immediate stop, then the AFR fluctuates and goes really lean (17-18:1). Then it settles back down to 14.7:1. This started happening after I installed the AEM intake. It is annoying and would like to fix it.
What specifically did you do to the open loop tables? Your talking about the two open loop tables in the rom, right?
Thanks
Old Jun 13, 2008 | 11:25 PM
Inprogress's Avatar
Hmm, ok I'll try and log it and post it here in the next few days since I'm out of town right now.
Thanks for all of the help everyone!!!
Old Jun 14, 2008 | 07:22 AM
nothere's Avatar
NJ,, I don't want to talk over JOT
but
pretty sure, as you think, he is correcting his fuel map in the area he saw the lean spot.
But, if I read him correctly, he is just talking about right after start up, when his car is still in open loop.
Sounds like you are referring to a warmed up car. In which case you could change the open loop load, that would change that problem area to a map tunable condition.
Since it sounds like an anomaly I'm not sure changing the open loop area will not affect a more general aspect of daily driving as well. Lets say you conquer the lean spot, since it may be a generally used load /rpm area, then that generally used area will be affected too.
hopefully, your lean condition is not normally exercised.
Old Jun 14, 2008 | 08:14 PM
Mr. Evo IX's Avatar
Inprogress, I made a video of my car on a cold startup this morning (85F 49% humidity, deep South Texas). It hunts at startup and again around 1:40, is that what your talking about?. You can hear little misfires here and there, something I always thought was pretty standard fare for an Evo.
http://videos.streetfire.net/video/C...Evo_166119.htm
Old Jun 14, 2008 | 11:25 PM
Inprogress's Avatar
Mr. Evo IX,
Did you turn on the A/C during that video?
I believe mine does what yours did during the start of the video (not sure because I couldn't see the RPMS clearly) but it was towards the start of it the video.
I also noticed it happening again during the 1.41 mark, I believe mine behaves the same way.
I'll try and take a video of it from my camera (I just realized my point and shoot records video w/sound) as soon as I get home.
Old Jun 15, 2008 | 07:06 AM
Mr. Evo IX's Avatar
AC was off.
Old Jun 28, 2008 | 01:33 AM
Inprogress's Avatar
Ok so I tried more logs, i did a near 20 min cruise and 14 minute idle log and the trims did not change. During the cruise, i went on hills so the car would see inclines and declines, but the trims did not budge out of 100.
I havent tried changing the scaling to see if that causes the trims to move around, so i'll prob try that soon.
Anyone have any other thoughts?
Old Jun 28, 2008 | 09:50 AM
oldevodude's Avatar
Maybe you could try the scantech software as that shows trims changing in realtime and then I think the ECU averages these values somehow and then writes them to your longer trim values like the one in Evoscan or mitsulogger. This might provide insight as to what is going on. My midterm trim would not budge if the scaling values was way off with my injectors.
Old Jun 28, 2008 | 10:37 AM
Ohhh, are you using the standard 100% scaling in evoscan? I had that issue at the beginning and when I changed everything over using the (0.1961*x)-25 formula for the +/-25% scaling, everything actually moved for the first time.
Old Jun 28, 2008 | 12:09 PM
Inprogress's Avatar
this is the current eval
0.78125*x
Is that off?
Old Jun 28, 2008 | 07:13 PM
Inprogress's Avatar
anyone?
Old Jul 9, 2008 | 11:52 PM
Inprogress's Avatar
I logged for over 16 minutes and the trims did not move while I was cruising. The formula is the one you're speaking of (0.1961*x)-25 and still no difference.
Any suggestions?
Old Jul 10, 2008 | 01:00 AM
RazorLab's Avatar
Was your 02 feedback % changing?
I use mitsulogger for fuel trims. Just seems to work better for me.
