Evoscan wierdness
Old Jun 19, 2008 | 06:57 AM
Nevonate's Avatar
Evoscan wierdness
I am currently using evoscan 2.1 .
When I review a log (graph) depending on what line I hover over, it gives me different values.
Example:
I'm looking a WOT log (throttle is 100%) and timing is 8 deg when I hover over the Throttle plot. When I hover over the timing plot in the exact same time, the throttle says 31.4% . I obviosuly know I'm at 100% and this wouldn't boether me, but it started happening to me when I was looknig at Knock.
Anyone have this problem? I cna upload logs if needed.
-Nate
Old Jun 19, 2008 | 07:12 AM
evo 8 ya's Avatar
So when you put your mouse pointer over a value/reading in your log, it changes the value/readings?
Old Jun 19, 2008 | 07:42 AM
TouringBubble's Avatar
I haven't used the EvoScan graph feature in a while, but i had the same issue ... it would randomly show different values in the graph and rollover than what was in the logs. There was a point where I had 3 different AFR values ... one in the log (correct), one on the graph when hovering over the AFR curve and another when hovering over a different curve.
Old Jun 19, 2008 | 07:55 AM
Nevonate's Avatar
Glad to see I'm not going crazy! I wish there were a better solution to evoscan's plotting.
Old Jun 23, 2008 | 01:17 PM
steadly2004's Avatar
have you tried the maptracer program?
Old Jun 23, 2008 | 01:26 PM
RazorLab's Avatar
There has been for quite some time:
www.dataloglab.com
Hiboost
47
May 19, 2010 09:00 AM
Rob_GPT
Jul 15, 2009 07:22 PM
nitz
Jul 4, 2009 09:14 AM
Broxma
Dec 28, 2008 04:24 AM
silverEVO8
AEM EMS
May 19, 2004 11:18 PM
