cables
Old Jun 23, 2008 | 12:18 PM
fknlowpsi's Avatar
cables
can i use the evoscan cable to reflash my ECu or do i need a tactrix cable???
Old Jun 23, 2008 | 02:59 PM
fknlowpsi's Avatar
bump
Old Jun 23, 2008 | 03:14 PM
EvoBroMA's Avatar
depends which evoscan cable you bought. they have 2, one flashes the other only logs. one is $80 the other is $70
Old Jun 23, 2008 | 03:26 PM
fknlowpsi's Avatar
i havent bought one yet. should i just go with the tactrix ?? it does both right ?
Old Jun 23, 2008 | 06:22 PM
krazirob's Avatar
well does the cable you got with your evoscan have two plugs.,....one should plug into the OBD II and the other should be attached and should be white in color which is the reflash portion of it and it plugs in to the left of the OBD II port
Old Jun 24, 2008 | 03:04 PM
fostytou's Avatar
EvoM Community Team
as of today, right now your best bet is the most recent evoscan cable with flashing.
That all will likely change very soon when the openport 2.0 cable is out from tactrix. Theres alot of answers to the advantages to either floating around right now.
Old Jun 24, 2008 | 04:12 PM
fknlowpsi's Avatar
i havent baught a cable yet. just wanted to know what would be better and if they both do the same thing cuz they dont look the same
SnailSpeed
Oct 31, 2016 12:55 PM
Evodetailer123
Oct 3, 2016 07:37 AM
GreeceS13
Jun 9, 2015 06:38 PM
djd24
Sep 3, 2006 11:25 AM
